Slow starting
Old Jun 10, 2014 | 09:20 PM
sonniek1025's Avatar
sonniek1025
Default Slow starting
Can anybody help I have mk4 escort efi xr3i IRS had a new starter motor/ ignition coil leads cam belt and new battery/
Run the car for about 20 minuets get nice and warm switch it off and then it will not start sounds just like a flat battery can anybody give me any ideas please
Old Jun 10, 2014 | 09:27 PM
RichieST's Avatar
RichieST
Quite a common fault I believe. It's usually heat from the exhaust manifold that causes the starter to overheat. Need a heat shield in there.
Old Jun 10, 2014 | 10:51 PM
Chopshop85's Avatar
Chopshop85
As above. Heat shield or wrapping the downpipe cured it on mine.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
ossie cossie
57
Nov 21, 2022 10:05 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
