Windows not winding up.
Just been out for a blast and now can't wind the windows up on my 2WD Saph. Replaced the 15 amp fuse that has a light and clock symbol on the fusebox cover as the plastic on it was melted, metal wire was intact. Now the indicators are not working either but hazards are. Just want to put the bloody thing away now!! Lol. Anybody got any ideas??
The fuse you have seen is for the fans, common problem and the circuit needs rewiring, as does the fuel pump!
As with anything the fuse most likely is not the problem (or if it is there is a reason for it blowing) in any case fuse 24 is for the windows (30 A)
You probably have just disturbed an adjacent fuse, therefore look toward fuse 20 (Has the indicator symbol respectively)
Martin
Martin
chowfornow
14
Jan 5, 2019 09:01 PM
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
