Anyone good with Snap-on OBD II fault codes?
Old Jun 5, 2014 | 03:55 PM
rog's Avatar
rog
Default Anyone good with Snap-on OBD II fault codes?
Basically I have a few isues with my M5, and kidnly got access to a snap on reader which I used on my car to clear the codes, but it seems the Snap on codes are not your 'usual' fault codes, does anyone know where I could find the corresponding fault codes a normal reader would generate?
i.e I know the first one on the list, 170, is PO411 in normal speak, but the snap on ones don't mean a lot to me
Old Jun 5, 2014 | 04:04 PM
James @ M Developments.'s Avatar
Grab yourself a version of PA Soft on ebay, works really well on the M5, you can reset all the adaptions etc on there.
Old Jun 5, 2014 | 08:12 PM
rog's Avatar
rog
Thanks, its been super reliable and all of a sudden I seem to have all this at once
Old Jun 5, 2014 | 08:27 PM
j6kyt's Avatar
j6kyt
have you cleared the codes and then run the car to see which one return straight away thats what i do as some dont always come back
Old Jun 5, 2014 | 09:02 PM
capri-rs's Avatar
capri-rs
these are decimal codes. not normal p0XXXX
some info here http://www.endtuning.com/bmwcodes.html
Last edited by capri-rs; Jun 5, 2014 at 09:50 PM. Reason: hex codes are not decimalcode
Old Jun 6, 2014 | 06:39 AM
oldford's Avatar
oldford
The fault codes are NOT OBD2/EOBD codes, but rather factory codes.
The Snapon scanner is using the factory protocol to retrieve the codes, which is better than the generic EOBD/OBD2 protocol as you usual can see more codes this way.
The numbers are different but the text should be somewhat self-explainatory.
However, I do believe that code 22 is for the Vanos on bank 1, not bank 2. Probably a small mistake in the Snapon scanner's database.
So, you have a defective cat on bank 2.
The secondary air pump is not working correctly.
There's a problem with the cooling fan for the ecu box.
There's a Vanos problem on bank 1 (Exhaust) which may lead to the mixture problem on bank 1 as well (code 144).
Old Jun 6, 2014 | 06:54 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Check for oil in the cam loom connectors and the lambda connectors, use the scanner to do a actuator test on the vanos motor/solenoid to see if its adjusting the rocker
CossieRich
30
Sep 8, 2015 10:08 PM
Alun Gregory
Sep 6, 2015 09:40 AM
nick8saff
Aug 16, 2015 05:35 PM
taylora1409
Aug 12, 2015 12:06 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
