headlights
Old Jun 4, 2014 | 09:21 AM
theb_o_z_z's Avatar
theb_o_z_z
Default headlights
i have a ford focus made in 2000 my problem is it is due for a m.o.t soon and a friend and i was going over it only to find that when i switch my full beam on my passenger side flashes and the drivers side gos out i also have two lights on permanety stay on one is the abs but i dont know what the other is for and 3rd and finnally thing my key tob will lock and unlock drivers door and boot but not passengers i would be greatful for any advice given
Old Jun 4, 2014 | 11:54 AM
Smudge374's Avatar
Smudge374
For your lights I would try changing the relay, other than that it could be the light stalk?
For the key fob, do all your doors open when you operate the central locking from the key in the door?
Warning lights are usually an advisory on an MOT, however if this causes the brakes to operate in effectively then you will fail the MOT.
Old Jun 4, 2014 | 03:05 PM
focusv8's Avatar
focusv8
A.B.S light on is a fail as is any light connected with the brakes, E.S.P and T.C.
You or someone will need to plug in a scanner to identify the A.B.S fault, most likely a wheel sensor.
Old Jun 4, 2014 | 04:10 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Remove the brake light bulbs one at a time and put them back in after rotating them through 180 degrees so that the "other" terminals make the connections
Before taking everything apart
Old Jun 5, 2014 | 01:48 PM
Oranoco's Avatar
Oranoco
Seen somebody do this before
Old Jun 5, 2014 | 07:00 PM
dojj's Avatar
dojj
my cousin had this on his cavalier, every time he pressed the brake pedal the headlights would flash, swapping the bulbs around solved the issue
Old Jun 5, 2014 | 09:08 PM
RichieST's Avatar
RichieST
The twin filament bulbs should be idiot proof as they have offset pins so should only fit in one way, I have seen so many different cars where the owner has either forced them in the wrong way wround or just fitted completely the wrong bulb, which causes havoc between the brake and lighting circuits.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
Kam B
Sep 24, 2015 10:40 AM
