YB Water Pump
Old May 31, 2014 | 08:14 PM
pauloopnorth's Avatar
pauloopnorth
Default YB Water Pump
Hi can anybody tell me if the water pumps is the same for a 200 4x4 block as for a 205 2wd block - Ive got a 4x4 200 block but a early 2wd cylinder head ? ,Many thanks
Old May 31, 2014 | 10:46 PM
cossie moon's Avatar
cossie moon
Durham RSOC member
You can fit either pump to the block if i remember right it just depends on what cooling system set up you using.
Old May 31, 2014 | 11:54 PM
nuttynil's Avatar
nuttynil
RS nutta
they both fit but the 4x4 one has different pipe work depends on what car you run ive got a 200 block 2wd head 2wd pump on a 2wd sapphire .
Old Jun 1, 2014 | 05:19 PM
pauloopnorth
Ok thanks for the help chaps
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
