Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
tailgate and passenger door lock prob
Old May 31, 2014 | 11:49 AM
ukjay's Avatar
ukjay
Default tailgate and passenger door lock prob
Im currently in the middle of fitting an after market alarm system, and ive lost the use of my tailgate switch and my passenger door wont unlock via the CDL with key.
Im 99% certain that I've blown or earth something out ( as i remember two wires touching and a bit of smoke coming off them , was only for a second ).
Problem is i cant seem to find the fuse or locate the faulty wire.
All the CDL works fine from the remote , so am i right to say the motor asnt gone on the passenger door ?
Car is 2004 Fiesta Zetec
Wires that touched was from the GEM unit , Blk/org in the green plug and blk/grn in the dark grey plug.
Old May 31, 2014 | 12:49 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you may have fried the gem bit inside that controls it or you may have fried the complete c/l system unit
they are fairly fragile
the remote working isn't related as it seemingly takes a different route to power the trigger motor
other than getting a complete wiring diagram up to find out which wire powers which thing in the boot (there are about 8 wires on the plug) it's a bit tricky to figure out
see if you can get power to the boot switch first from the outside and work back from there
Old May 31, 2014 | 02:06 PM
ukjay's Avatar
ukjay
Thx for reply .... If its the GEM unit does it after av the same part number as ive seem 1 on ebay with part no ... 2S6T 15K600 BF and mines 4S6T 15K600 BA
Old May 31, 2014 | 05:14 PM
dojj's Avatar
dojj
Other ones will work, but they may not have the functions as yours
Also get one from a higher spec car as somethings might work but do remember that you will have to reprogram the alarm fob in most cases
Old Jun 1, 2014 | 06:40 AM
ukjay's Avatar
ukjay
ok ill keep that in mind .... thx again for advice
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 24, 2015 11:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
gcfcos
88
Sep 15, 2015 03:48 PM
The Enigma
Sep 12, 2015 10:12 PM
