widest tyre on the rear of a saff with 6 deg beam
Old May 30, 2014 | 05:33 PM
james kiely's Avatar
james kiely
Default widest tyre on the rear of a saff with 6 deg beam
any chance you can run wider tyres on the rear of a 2wd saff when using a 6 degree beam .i dont mind rolling the arches if needs be
Old May 30, 2014 | 05:55 PM
J1mbo's Avatar
J1mbo
B1mbo
Wi rolled arches and 17s I bet with the right offset you could squeeze a 235
My wheels fill the arches on 18s and I'd get 225 no bother
The only issue is when they squat hard they can catch the inner arch
Old May 30, 2014 | 06:01 PM
james kiely
cheers jimbo ,i will be running et35 8x18 montes
jimbo what profile are you using 35 or 40 ?
Old May 30, 2014 | 10:55 PM
J1mbo's Avatar
J1mbo
B1mbo
Et 35 is about 5 mm further in than mine so you should be fine 225. I use 35 and will be going upto a 225/35 when these pirellis are dead
Old May 31, 2014 | 10:17 AM
james kiely
cheers jim,i would love to get a 40 profile tyre on tbh
Old May 31, 2014 | 10:27 AM
J1mbo's Avatar
J1mbo
B1mbo
Yeah I know what you mean, they look a bit big on 18s a 235/40/17 is a nice tyre size for rear of saff.
Old May 31, 2014 | 05:43 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I have 235/40/18 on mine with arches trimmed back.
Old May 31, 2014 | 05:50 PM
james kiely
that sounds good rod as i dont mind trimming the arches .
your on toyo,s too which tend to be wider still,i have been looking at federal rsr ,s?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
turbowag
Sep 3, 2015 08:07 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
