My Dyno result
Old May 21, 2014 | 05:44 PM
luxembourgrst's Avatar
luxembourgrst
Default My Dyno result
hy I took my escort s2 on the dyno
here are the spec :
piper cam 285 t
stage 2 brand new turbo
mongoose exhaust
open air filter
bailey dump valve
group a coil
7200 rev limit
no limit boost ECU
Boost set up like 1.2 Bar
AFR on idle 14.7 AFR on boost 11
timing set at 8 degree
the car drive nice no bugs or detontion
well here are the dyno diagram but only 160.4 PS (bhp) on engine
and 139 on the wheels
and 243 NM torque
free image uploading
upload image free
image hosting over 10mb
print screen
Old May 21, 2014 | 05:53 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
sounds like its to rich on boost for a start mate
Old May 21, 2014 | 05:57 PM
mattxr3i's Avatar
mattxr3i
Impressive transmission losses at 12%, must be a very good gearbox you have
Old May 21, 2014 | 06:32 PM
Red_bull's Avatar
Red_bull
I would expect much more power on this boost! You increased your boost from 0.5 (std) to 1.2 and you gained 30 bhp
Do you have some photo's from the dyno set up? Did it have a good cooling block in front of the car?
Old May 21, 2014 | 06:36 PM
Chopshop85's Avatar
Chopshop85
What is the difference between a stock and stage 2 turbo?
Old May 21, 2014 | 06:56 PM
luxembourgrst
it s shiftech dyno yes they did have a cooling but I don t know if it was on or off normaly on
well not enough boost? why only 160 ps I was thinking about 185 -190 like maximom on MFI
Old May 22, 2014 | 06:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
A little low for 17psi (if it's held to limiter?), would of expected around 185bhp.
Perhaps a little more timing and a little less fuel would see the gains you expected.
Old May 23, 2014 | 09:12 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
8 degree advance is 4 degree less than what the book states @ 12degree. If you set it to 14 degree and sorted the fueling out and cam timing with that boost you should see closer to 190bhp.
The jets or boost control is not set correctly either as the curve is shite.
Old May 23, 2014 | 03:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
360 degree thrust bearing and a 50 trim compressor wheel.
luxembourgrst What are you using for boost control?
Old May 23, 2014 | 07:22 PM
luxembourgrst
well over 1 bar boost we have to put our timing to 8 degree no?
the fueling is ok no? 11.00 afr on boost is save ?? or is it to rich?
more timing would say to go back to 12 degree?
Old May 26, 2014 | 06:54 PM
Red_bull's Avatar
Red_bull
Didn't say not enough boost mate! I expect more power on the boost you are running. I have ran wel over 160 bhp with about 1 bar.
I did have a flowed head
I like the photo's and love the looks of your car!
Old May 26, 2014 | 07:12 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
what intercooler are you using and what were your charge air temps
Old May 26, 2014 | 07:48 PM
luxembourgrst
airtec front big intercooler
for the temp I don't know sorry
but few days ago in set my ignition timing on 12 degree an yes the car sounds more powerfull ( at high rpm I looks like it s on the limit of dentoantion ) but drive fine have to go back on a dyno
and I looked better on the turbo pressure gauge an it hit the max of 1.4 bar and my AFR is always at 11.8 on cruising an on boost at high rpm..
Old May 26, 2014 | 09:23 PM
Versus_Creations
Ask me a question!
12 degree is still not enough. You will need to monitor fueling carefully but will be fine if everything is working how it should.
Old May 26, 2014 | 09:26 PM
Versus_Creations
Ask me a question!
Just to add that 1.4 bar is on the limit. If you was to run less boost and more ignition with a decent boost curve you would still make more power than running high risky boost on a system that can go out of sync very easy. Which will no doubt cause failure.
Old May 27, 2014 | 08:40 PM
luxembourgrst
yes I will try this
Old May 28, 2014 | 10:24 AM
Karlos G's Avatar
Karlos G
Balls Deep!
You would start tuning from around 8 degree's, advancing it and matching the fueling to your desired boost until you found detonation.
There is not one figure you can use for everyone as each engine configuration can be very different.
Old May 28, 2014 | 10:35 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Telling him to advance his timing without knowing how close he is to det is very dangerous advice! You could have just killed his engine!
Old May 29, 2014 | 07:51 AM
Versus_Creations
Ask me a question!
Shut up Karlos.
How many engines do you think I have tuned.
Of course he is aware that any self tuning of his engine can kill it.
I'm telling him what i can run on every mfi engine i have tuned. None of them have issues running that advance as his engine won't as long as it's all tuned properly.
Now go away do some practice and r&d then come back with your 2 bobs worth
Most decent tuned mfi engines can run upto 17 degree. So his still safe.
You obviously wouldn't know that just yet,
Old May 29, 2014 | 08:34 AM
luxembourgrst
bad boy bad boy what you gonna do?
well
I m on 12-13 degree timing but the engine sounds like if I put it to 14 I will gonna have detonation..... if I want to put it to 14 I have to puch the turbo pressure down no?
Old May 29, 2014 | 09:04 AM
Versus_Creations
Ask me a question!
"Sounds like" and "is" are two different things
You must have a set of cans fitted to do all this and also a good wideband as close to the downpipe as you can.
You need to make sure the cam timing is spot on, then make sure the fuel is keeping up as some metering units, just for what ever reason internally cant flow the fuel. Sometimes injectors or sensors etc have issues. Stating the obvious that everything needs to be working well.
If ACT is below 45degree and timing set to 14advance with base fuel of 3% you will not get any signs of det.
Make sure you have super unleaded at all times.
Old May 29, 2014 | 09:06 AM
Versus_Creations
Ask me a question!
Just to add.
This is just the end of the tuning methods, before all this you should read the setup guide to make sure everything else is how it should be at base settings. Fuel pressure and static settings.
I hope this helps you out, like I say this is first hand tested and tried with proven results.
Old May 29, 2014 | 04:08 PM
luxembourgrst
well do you think 1.4 bar is to mutch?
an I need to put timming to 14 degree?
Old May 29, 2014 | 07:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Shut up Karlos.
Without being there in person you cannot tell anyone to run any advance... how do you know his ECU is retarding the timing properly as boost increases? How do you know his charge temps are not sky high? What are his EGT's?
I prefer not to guess and take risks with people's cars... but that's just me, you carry on mate.
Old May 29, 2014 | 10:32 PM
Versus_Creations
Ask me a question!
his in Luxembourg ffs we are never going to get these answers all we can do is give him decent guidance.
YOU WILL need to monitor fueling carefully but will be fine if everything is working how it should.
maybe you missed this....
Old May 30, 2014 | 02:08 PM
Canada1's Avatar
Canada1
Hello Jano,
I have never seen the factory Ford RST total timing map.
I would assume that is is very conservative.
The factory unmolested timing map must reduce timing based on boost levels.
As factory was limited to (8psi?) does the stock computer reduce timing at higher boost pressures - or does it reach a maximum boost retard at 8 psi or more?
Any idea what total ignition timing is at 1 bar and 12 degrees (factory setting)?
Does the factory Ford computer change timing vs. RPM and Boost?
A factory map would be awesome to see.
Old Jun 5, 2014 | 07:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Telling him to advance his timing is not decent guidance.
No I didn't miss that, but it's det he should be monitoring, even if the fuelling is spot on there are so many other factors (as I mentioned above) that can cause it to det.
Originally Posted by Canada1
Hello Jano,
My understanding is that beyond factory boost no it does not pull timing, you have to manually move the distributor to retard it for higher boost settings, some chips have a revised spark map but most just remove the boost cut and I do not know what the factory MAP sensor reads too either.
Old Jun 5, 2014 | 08:37 PM
Turbosystems
Super Moderator
The std ecu is mapped to 10 psi alot of after market chips just remove the boost limit and can therefore only read 10 psi
The std pressure sensor is a frequency out put sensor the ecu processor can be altered to read upto 23 psi and have an ignition map to suit.
All our chips had raised boost limits and properly mapped ignition curves
Some ecu mods were not even a chip or properly mapped chip they were nothing more than a micky mouse board that limited the map sensor out put to never effectively see above 8 psi of boost if they worked at all
Old Jun 6, 2014 | 01:20 PM
Canada1's Avatar
Canada1
Fantastic, Thank you.
Old Jun 6, 2014 | 10:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
That's an excellent post thank you!
So based on that, most chips (excluding your's and I believe Ahmed chips?) would be running 8psi advance at that and above! What is the factory advance at that boost, 20-25 degrees?
Old Jun 7, 2014 | 07:01 AM
Versus_Creations
Ask me a question!
You must have a set of cans fitted to do all this and also a good wideband as close to the downpipe as you can..
Again you must only read what you want to see...
Old Jun 7, 2014 | 08:15 AM
luke19790_3's Avatar
luke19790_3
Posts 8 and 14 you tell him to advance is timing, it's after Karlos questions you that you mention det cans
Old Jun 7, 2014 | 10:36 AM
Karlos G's Avatar
Karlos G
Balls Deep!
IMO It's just too risky with the age of the fuelling/ignition systems.... Based on Jano's advice people reading this will think it's safe to advance their timing to 17 degrees, set their base CO to 3%, run higher boost and all hoping/assuming that everything is working as it should is just going to result in a lot of dead engines
Old Jun 7, 2014 | 11:04 AM
luke19790_3
Alot of work for someone then
Just bin that mfi stuff and buy 2nd hand cossie gear, bargain at Ł1500 but where do you go to get the answers
Old Jun 7, 2014 | 12:17 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Based on Janos advice and handywork my car runs awesome at 26Psi and plenty of ignition its all holding together well, i dont think there will be many CVHs keeping up with it. he also has loads of other customers in the same boat.
it also starts on the button and drives of boost better than any MFI car ive ever owned.
Old Jun 9, 2014 | 04:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Good to hear that some MFI cars are still in good working order mate.
Old Jun 9, 2014 | 07:51 PM
luxembourgrst
well my setup is know
12.5 AFR on boost boost at 1.3 bar
ignition timing at 12-13 degree
the car runs fine and powerfull need to go back on a dyno to look if I have more horse pwer
Old Jun 9, 2014 | 08:54 PM
Red_bull's Avatar
Red_bull
You probably will have more horsepower. But my friend you don't need to go for a hp check, but to make sure everything is safe. No det with det cans, AFR everywhere right.
Don't drive it anymore before you have everything checked.
Old Jun 10, 2014 | 08:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
IMO 12.5:1 is a bit to lean at 1.3bar, I would run at least 12.0:1 just in case you're not fuelling evenly on all four cylinders for example... little bit of safety margin.
Old Jun 26, 2014 | 12:22 PM
Stu @ M Developments's Avatar
PassionFords Creator
8 degrees eh? Interesting number... and I will tell you why...
A very big and common problem with these old systems now, and so far unmentioned by anyone, is the map sensor in the ECU dies and cannot see boost anymore and thus the timing stays static. In these cases the base ignition angle tends to end up at... wait for it.... 8 degrees... otherwise it dets its brains out on 97ron from about 10 upwards.
Maybe the tuner knew exactly what he was doing, but not why this vehicle needed so little advance. Very few people understand Bosch KE and understandably so, its prehistoric and quirky at best.
Also, given this chap is overseas, he likely isnt running the same octane fuel as us. How come nobody has asked him? Tweak with caution boys... Internet tuning can be very dangerous. LOL
