Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
All the dash lights on! Please help
Old May 18, 2014 | 01:30 PM
flowgraphyc's Avatar
flowgraphyc
Exclamation All the dash lights on! Please help
Hello everyone!
I have a Ford Fusion 2003 with Durashift semi-auto gearbox.
Lately I've been having some issues - all this nightmare started one morning when all the dashlights turned on, on the monitor that indicates what gear you are in are 2 horizontal lines, mileage disappeared, tachometre fluctuates from actual number of rotations to zero, and so does the mileage clock.
I verified the car battery, even changed it. Cleaned the battery minus, cleaned the grounds and stilll doesn't work. I checked the board clock, the wires and plug seem to be ok.
I had the car tested and had many fault codes most of them telling that 'it lost the connection with PCM. I'll write down some of the codes:
U2012, U2523, P1799, U0155.
After erasing all the fault codes I started the car, it came back to normal. I checked again and there were no more errors. The next morning all the lights turned on again...
Does anyone know what could be wrong? Do I have to change the PCM also?
Has anyone had this kind of problem before? Please help
IainRS1700T
Sep 25, 2015 06:44 AM
The Enigma
Sep 12, 2015 10:12 PM
imnoteasy
Sep 7, 2015 09:26 PM
