Pics of cosworth management trigger on cvh
Old May 17, 2014 | 06:29 PM
Hansenturbo's Avatar
Hansenturbo
Default Pics of cosworth management trigger on cvh
Hi I am looking for pics of trigger sensors setup on crank and camshaft
Thx Brian
Old May 17, 2014 | 07:06 PM
studabear's Avatar
studabear
I've got pictures of when I had the oddkidd set up fitted if it helps?
Old May 17, 2014 | 07:19 PM
Hansenturbo
Thumbs up
yes i would like to see them thx
Old May 17, 2014 | 07:25 PM
Gadget's Avatar
Gadget
Spanner monkey
Old May 17, 2014 | 07:29 PM
gus's Avatar
gus
Looks good Gary
Old May 18, 2014 | 04:22 PM
Hansenturbo
thx gadget
can you explain to me how to insure the sensor are at the right position .
the thing is my head is mfi and i want the get away from my welded dizzy (leaking)
so i have bought new bracket kit for cam and crankshaft.
i know you can do this in your sleep LOOOL but not me :0)
Thx Brian
Old May 18, 2014 | 08:14 PM
Gadget's Avatar
Gadget
Spanner monkey
Hi Brian.
For the crank, when the engine is at TDC, you want the sensor lined up with one of the four teeth on the trigger wheel.
For the cam, at TDC, the first of the two teeth should be 3.5 teeth back from 12 o'clock ( I think it's 36 degrees before )
Old May 18, 2014 | 08:16 PM
Gadget's Avatar
Gadget
Spanner monkey
You can see that in pic 8
Old May 19, 2014 | 05:41 PM
Hansenturbo
Thumbs up
Thx for help m8
Old May 19, 2014 | 06:15 PM
Gadget's Avatar
Gadget
Spanner monkey
This ones shows exactly where the first tooth goes when at tdc
hope it helps!
Old May 19, 2014 | 06:37 PM
Hansenturbo
Super thx again m8
Old May 29, 2014 | 03:56 PM
foci18's Avatar
foci18
Sorry to hijack your thread have you got a pic of an efi inlet before it's been modded to cossie management cheers
Old May 29, 2014 | 04:04 PM
studabear's Avatar
studabear
I will post a pic in the other thread
Old Nov 7, 2017 | 06:17 PM
Rsmat's Avatar
Rsmat
Anyone selling a trigger sensor kit ?
Old Nov 28, 2017 | 08:02 PM
Gadget's Avatar
Gadget
Spanner monkey
I've got trigger discs Matt, I'll have a look if I've got any more brackets!
Gadget's Avatar
Gadget
Spanner monkey
Cam or crank?
bigryrs
Mar 28, 2016 09:11 PM
jay030787
Sep 18, 2015 07:34 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
