Rear beam bush help
Old May 15, 2014 | 09:34 PM
Tinshaw's Avatar
Tinshaw
Default Rear beam bush help
Hi all just tried to fit the rear beam on the cos, & it's as if the bolts aint long enough to get a thread to tighten?? I've had new power flex bushes am I doing something wrong?? Or is there a special way of doing this?? or do I need longer bolts?? It's the long 1's out of the 3 I mean. Thanks in advance.
Old May 16, 2014 | 08:24 AM
cossie moon's Avatar
cossie moon
Durham RSOC member
Bolts are correct as its fiddly to do with new poly bushes till they've been in and squashed abit. Theres a few ways to do it either put other 2 bolts in till you can get big bolt in or some people use a jack as you only need a few mm to do it.
Old May 16, 2014 | 10:21 AM
dojj's Avatar
dojj
Resident Wrestling Legend
There should be a metal sleave in there somewhere to locate the bush bolt into the car
If its not aligned properly it will seem like its too short
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
