Drive shaft help ASAP
Old May 15, 2014 | 06:22 PM
Tinshaw's Avatar
Tinshaw
Default Drive shaft help ASAP
Hi guys need some help ASAP, I'm fitting the front drive shafts back on the saph 4x4 cos & I've got 2 different 1s..... I can't remember witch side goes on witch?? Does it matter as the both the same size but look different?? Cheers in advance.
Old May 15, 2014 | 06:46 PM
Cossy Mike's Avatar
Cossy Mike
They both the same.....only difference is the inner and outer joint, the tripod joint goes inner
There's a shaft that runs through the sump. There's a circlip on the drivers side, inside the front diff
Old May 15, 2014 | 07:22 PM
Tinshaw's Avatar
Tinshaw
Hi my to inner joints are both different in apperance? does this matter?? Thanks Lee
Old May 15, 2014 | 07:26 PM
Cossy Mike's Avatar
Cossy Mike
So long as the depth, spline count and assembled length is identical it shouldn't matter.
I suspect you have an original (has a boot clip with no join in it)
and an after market one
Old May 15, 2014 | 07:41 PM
Tinshaw's Avatar
Tinshaw
Hi thanks for yr help, 1 other thing I've had all the hubs sand blasted & powder coated & the rears, the new bearings I've had to hammer down, but the fronts where they sand blasted the wrong part! The bearings are just sliding down, does that mean them 1s are now scrap!!
Old May 15, 2014 | 08:24 PM
Cossy Mike's Avatar
Cossy Mike
The bearing race in the front hubs should be tight, I've just had mine done last weekend so can relate to this.
You can get a machine shop to fit you an inner race if it's worn, then your bearing race will sit inside this snug.
More expense or buy another pair of knuckles. Are you sure they are 4wd bearings and not 2wd?
To be honest I can't see how blasting could have took any off it, it would have had to have been really high pressure or too coarse of a bead to kill your hub
Old May 15, 2014 | 09:29 PM
Tinshaw's Avatar
Tinshaw
I had a full set of bearing from graham Goode so I would of thought he sent the right things out, & i meant the steam part of the hub sorry where the wherl bolts the other side, i should of made that clear!! as for the sand blasting I'm not sure what they done!! As I had them done at different times, 2 are fine 2 ain't?? 2 are a tight fit as they should be, & the other 2 (which were blasted) you can slide the bearing of with your hand!!
Old May 16, 2014 | 04:26 PM
col93saphcos's Avatar
col93saphcos
Mine did that, just replace drive flanges,4x4 xr's are the same drive flanges,hubs different tho
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Flateric_2002
Sep 15, 2015 08:41 AM
Bransby
Sep 11, 2015 09:12 PM
rsstav
Sep 7, 2015 04:43 AM
