Need Help from Italy,Coil Spring
I bought a pair of front Coil Spring to restore the original height of my Escort (because are too low). From a online part site i buy coil spring NK code 532516 (the code seemed corrected..... for my car...but).....the coil spring are too high!
Anyone can tell me the number of the original coil spring?
Its not correct to your car, the part box says Escort/Orion. The RS turbo came with unique springs, You need to search for Escort RS turbo springs and not the run of the mill spec.
This is an auction for pattern parts, its the ones you are after:
http://www.ebay.co.uk/itm/Ford-Escor...item4d1903f651
SMILER258
Sep 28, 2015 09:04 AM
