Series 2 injector plate removal.
Old May 13, 2014 | 05:03 PM
Perfmr2's Avatar
Perfmr2
Default Series 2 injector plate removal.
Quick question, how does the injector plate seperate from the head,. Ive got manifold off, and the one centre nut, am I missing something?
Old May 13, 2014 | 06:26 PM
haz87's Avatar
haz87
Nope, should just pull off (the studs can make this tough sometimes but it will slide eventually)
Old May 13, 2014 | 08:14 PM
Red_bull's Avatar
Red_bull
Did the centre nut come out with a bush. Else that might still be in if i am not mistaken
Old May 13, 2014 | 09:30 PM
simonmcf's Avatar
simonmcf
Do you have all the bolts removed? If I remember correctly I could not get mine off until I noticed the middle one
Old May 14, 2014 | 07:43 AM
XR2's Avatar
XR2
When you've taken all of the nuts off, use a chisel or a flat screwdriver (without a hammer!) to separate the plate from the head. You've got to use an adhesive sealant for the coolant opening in the middle of the cylinder head and this is sometimes hard to remove.
Old May 14, 2014 | 09:04 AM
Perfmr2's Avatar
Perfmr2
Thanks for all the replies guys.
Came off with a little gentle persuasion from the council screwdriver.
What sealant do I need for the coolant opening when I reassemble?. Will black Sikaflex do the trick?
Also whats best to use to clean block and head before new head gasket goes on?
Wet & Dry and WD40?
Old May 14, 2014 | 09:13 AM
XR2's Avatar
XR2
The right gasket and something like Universal blue by Hylomar. Apply on both sides.
Scratch the rest of the gasket off with a sharp blade, something like a box knife etc. Then use brake cleaner and dry paper.
Old May 14, 2014 | 07:07 PM
Perfmr2's Avatar
Perfmr2
Luckily the old gasket came off in one piece.
Use sealant on the gasket?
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
cos elle
Sep 16, 2015 06:37 PM
