Rocker cover gasket and sump
Old May 12, 2014 | 02:51 PM
Mats1985's Avatar
Mats1985
Default Rocker cover gasket and sump
Which are the best gaskets to get and any tips in fitting both please
Old May 12, 2014 | 03:10 PM
haz87's Avatar
haz87
Any brand rocker cover gasket tbh if your torquing correctly.
Sump gasket, Payen or Genuine Ford (tho they're just Payen anyway)
Old May 12, 2014 | 03:35 PM
S2 Cabby's Avatar
S2 Cabby
Always preferred the rubber rocker cover gaskets to the cork ones myself
Old May 12, 2014 | 03:56 PM
Mats1985's Avatar
Mats1985
Any1 know the tourque settings for both
Old May 12, 2014 | 04:22 PM
s1cab's Avatar
s1cab
Torque setting is 8 NM
Old May 12, 2014 | 05:36 PM
Dan F's Avatar
Dan F
Has a bit of bother with my rubber one so went back to cork on mine on both cars with no bother since
Old May 12, 2014 | 07:00 PM
S2 Cabby's Avatar
S2 Cabby
Fitted my rubber one nearly 4 months ago and it's been fine since
Old May 12, 2014 | 07:04 PM
mentalasanything's Avatar
mentalasanything
I also had issues with the rubber rocker gasket so I'm using cork.
Tip for fitting the rocker cover gasket: Apply a thin layer of grease to each side of the cork gasket before fitting. Use no sealants.
Tip for fitting the sump gasket: thoroughly clean the sump and block, take the new gasket and super glue it in place on the block, holding it there with the bolts. Once the superglue is dry, remove the bolts and fit the sump, torquing it correctly.
Lee
Old May 12, 2014 | 09:38 PM
Red_bull's Avatar
Red_bull
i am using the rubber onces, but from burton. I don't know if its because of the burton onces or just all of them but i think they are a pain in the ass to fit and they always keep leaking!
I pay about 40 pound for a ford one! Are they also as expensive in the UK?
Old May 12, 2014 | 09:43 PM
mentalasanything
I buy all my gaskets from a guy called "Gaskets for Classics" on eBay. I think I paid around £50 for a whole head set including a Payen head gasket. £40 from ford sounds a lot.
Lee
Old May 20, 2014 | 10:25 AM
S2 Cabby's Avatar
S2 Cabby
I spoke to soon, just after saying this I noticed a few drops of oil on the floor and thought it was the sump gasket leaking by the pully but after giving a real good clean up I found out it was the new rubber rocker gasket new cork one fitted now so fingers crossed.
Old May 20, 2014 | 07:32 PM
tlr_rst's Avatar
tlr_rst
i used rubber rocker gasket as the cork one weeped, i just tightened it still my fingers bleed almost then retighten it after a few more days. Its really tight. been on months now with no problems what so ever.
as for the sump just tighten till it almost squeezes out the side then slightly loosen so it goes back in. doesn't leak, been on 17 months now dry as a dink dong
Mark RS
Mar 5, 2021 06:08 PM
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
youngben
Sep 27, 2015 09:37 PM
