Cosworth Inlet Support Bracket
Old May 11, 2014 | 10:38 AM
Sonic Boom's Avatar
Sonic Boom
Default Cosworth Inlet Support Bracket
While I was changing my starter motor, I noticed my inlet support bracket had broken clean in half
So I went about making something seriously stronger and better mounted too.
Wish i'd taken more photos as usual and they aren't the best quality due to poor light and being on my iPhone.
I made a little bracket out of 5mm Stainless Steel and attached that to the top bolt on the engine mounting leg, then connected the bracket to the inlet with a 130mm Turn Buckle and M8 rose joints either end.
Alot stronger now don't think i'll break this one.
Rich
Old May 12, 2014 | 11:14 AM
ChrisB4x4's Avatar
ChrisB4x4
If In Doubt Flat Out
Looks alot stronger than the little bracket that bolts to the top of the engine mount on mine.
Old May 13, 2014 | 07:43 AM
cossynut2's Avatar
cossynut2
10 Year Member
Smile
Rich
Nice one, makes you wonder why Ford never made one like it.
Old May 13, 2014 | 10:29 AM
cossiestu's Avatar
cossiestu
Think mine must of snapped years ago, before I had the car, it's never had one fitted for as long as I've owned it!? :-o
Touch wood, the inlet an plenum haven't fallen off yet....!
Old May 13, 2014 | 06:31 PM
costina's Avatar
costina
Live long and prosper!!
Originally Posted by Jay,
It is not a bracket its a resernation/harmonic damper
It also has dished type washers on it too.
If it was a bracket holding the inlet up the 6mm stud would break before the bracket.
Old May 13, 2014 | 07:20 PM
BRAMMER's Avatar
BRAMMER
I modded the standard bracket to fit the Hart inlet, then fitted the washers Burton sell and i can't see how it would break as using the washers gives movement
Old May 13, 2014 | 10:42 PM
Sonic Boom's Avatar
Sonic Boom
Well what ever it's call it broke, when I ran it without it cracked the inlet ports on the head had to get them welded back up.
That's exactly what I did extended a standard bracket and fitted the washers in the specifed order and it still broke.
This bracket will support the weight of the Hart inlet and stop it cracking the head much like a turbo hanger stops you cracking manifolds.
Rich
Oct 9, 2015 07:38 PM
Danielbetty
Oct 3, 2015 06:01 PM
Aug 20, 2015 09:21 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
