Scholar Engines suffolk
Had some machining work done by them for my dads Essex v6 with no issues, They build a lot of race engines so a head refurbish shouldn't pose much of a problem.
If not SCS may be a better option as Yb's are there speciality.
Scholar have a good rep as far as i'm aware. I'd also look at http://www.roperdevelopments.co.uk/c...head-costs.htm - he's in haverhill if i remember correctly.
hi mate I tried these in January for a yb engine build skim pistons valve cut out etc compression change etc. but they could not give me any straight answers. they had it for over a month and all they did was skim the fly wheel and grind the crank. they said they could do the work but they are not set up for valve pockets etc and they where not sure no my block as it was wire rung. so I rang scs Harvey gibbs how was very helpful told me what he could do and how much it would be over the phone long studs the lot for a very reasonable price aswell. work is all done engine is all in and run like a dream. the quiets yb I have ever heard
