t3 banjo snapped
Old May 3, 2014 | 11:22 AM
roxy.86's Avatar
roxy.86
Default t3 banjo snapped
Hi all, this is my first post so sorry if I've posted in the wrong place.
was removing my t3 turbo from my 4x4 saph and one of the banjo bolts was so rusty it snapped, going to need a replacement bolt but not sure of the thread pattern (correct bolt) all I know is mine has a 24mm head had a look on ebay but don't want to end up buying a dozen just to get the right one so thought for once id ask you knowledgeable chaps? Thanks in advance
Old May 3, 2014 | 04:05 PM
killa_paul's Avatar
killa_paul
give burton power a call mate
Old May 5, 2014 | 05:01 PM
Cossy Mike's Avatar
Cossy Mike
There was only one place I could find that had them,
http://shop.grahamgoode.com/banjo-bo...62-59408-p.asp
The others had the same diameter all the way through the bolt,
like this
http://www.ebay.co.uk/itm/Garrett-Tu...-/330943801614
you'll need the ones from GGR
Old May 5, 2014 | 05:02 PM
Cossy Mike's Avatar
Cossy Mike
Mine was a standard T3 off a 4wd saff Red top also, take no notice of the Escort T35 description.
Old May 5, 2014 | 05:14 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
measured on a b&q tape
17mm thread 24mm washer head , 13mm bolt head, that's a banjo off a t3
Old May 5, 2014 | 05:37 PM
cozzy jeff's Avatar
cozzy jeff
would them measurements be different if you used a tape from wickes??
Old May 5, 2014 | 06:14 PM
mk2grp1's Avatar
mk2grp1
maybe baby
Old May 5, 2014 | 11:07 PM
closeshave's Avatar
closeshave
expert
What if you used one from blockbuster? (VHS)
Old May 8, 2014 | 03:16 PM
roxy.86's Avatar
roxy.86
Thank you just ordered will be here Monday so I can get it sorted. Thanks again
pabloXR
Sep 21, 2015 12:42 PM
