Bubbling window rubbers
Old May 1, 2014 | 09:55 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default Bubbling window rubbers
Looks like the strip inside the drivers window rubber has corroded causing bubbling through the rubber. There is no way I'm paying the £90 plus on eBay for a bit of replacement rubber!
Anyone either repaired it or found an alternative to being royally ripped off?
Old May 2, 2014 | 06:57 AM
rog's Avatar
rog
They're slightly cheaper from Ford, about £70 each, I just bought some about a month ago, rear ones are not available anymore though.
Been looking for an alternative, but haven't had any joy.
Old May 2, 2014 | 07:32 AM
cossynut2's Avatar
cossynut2
10 Year Member
Talking
A few years ago I found some in a small local Ford garage which was moving to a new site and was lucky to get 2 for just £23 each ! If you have any old established small Ford garages around where you live give them a try. To me £90 plus is a rip off price.
Have you looked at what has caused the bubbling ? You will need to fix it before you fit your new rubbers or the same thing will unfortunately happen again.
Old May 2, 2014 | 07:41 AM
paalrosen's Avatar
paalrosen
Have you looked at what has caused the bubbling ? You will need to fix it before you fit your new rubbers or the same thing will unfortunately happen again.[/QUOTE]
Rubber lists are reinforced inside with a steel profile? are they not,
it is for sure how the sunroof seal is made​​, rusting from the inside out.
may be that is why it bubbles,
* can be a little rust under there the list is fitted to
Old May 2, 2014 | 09:23 PM
Jimboxr4x4's Avatar
Jimboxr4x4
That's right, the door is fine, it's just the steel strip inside the rubbers that corrodes.
Old May 3, 2014 | 02:35 AM
whiskey's Avatar
whiskey
have you tried east kent trim supplies? not sure if they will do what your after but worth a call
Old May 3, 2014 | 09:15 AM
Jimboxr4x4's Avatar
Jimboxr4x4
Good suggestion. I rang them up but they don't currently do them unfortunately but are looking into doing them in the future.
Old May 3, 2014 | 07:08 PM
paalrosen's Avatar
paalrosen
the same with the sunroof seal. they will start production in a few years
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
