Bad Idle? what can i be..
Old May 1, 2014 | 04:14 PM
TomrsT's Avatar
TomrsT
Default Bad Idle? what can i be..
When it is started it idles good, until it comes on boost.
Where do i need to look for this?
Old May 1, 2014 | 04:58 PM
Oranoco's Avatar
Oranoco
Air leak at a guess, if you have a DV take it off and see if that improves. Worth checking th eheavy plastic pipework that runs from the left rear of teh rocker cover to the metering head as this can crack and cause problems.
After that without the car in front of me it's a bit tricky to diagnose
Old May 1, 2014 | 05:24 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
hi it could be related to the air sensing plate , remove air box
start car do all the revving by hand, don`t pull the cable, twist the mechanism at the throttle body, , your air plate could be returning too far and starving engine of air, 2 minute job to adjust the plate rebound stop, if that is the problem,
Old May 1, 2014 | 06:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Just to pint out it isn't running right from start either, it's lumpy.
Air leaks is always the first thing to check as above, if there are none then the fueling and timing should be checked.
If you mean the flap in the metering unit then what you describe as the rebound stop is the idle mixture screw.
Old May 1, 2014 | 06:22 PM
mk2grp1's Avatar
mk2grp1
just help they guy out if you can, don`t try to be smart
Old May 1, 2014 | 06:26 PM
tlr_rst's Avatar
tlr_rst
when i renewed my crankcase breather filter the revs raised to 1.4k and it was all gunky, so it was now breathing better, as in i had to turn down the idle screw and have the co mixture checked
Old May 1, 2014 | 07:31 PM
TomrsT's Avatar
TomrsT
I don't have a DV installed, all original.
Going to check the auxiliary air valve and the pipework for leaks tomorrow.
Some photo's
Old May 1, 2014 | 08:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I wasn't being smart, I was helping the guy?! lol
The breathing doesn't effect the idle directly as such, sounds like you either fixed or created an air leak without knowing it.
Old May 3, 2014 | 09:59 AM
Sava Ford's Avatar
Sava Ford
I have similar problem before few month and fix it with allen 3 (I don't know is correct) for me it was bad mixture
TPM961
Jan 15, 2018 10:50 AM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
RSmark84
Sep 13, 2015 01:29 PM
