speedo information needed
Hi,
My speedo has failed on my 4x4 sapphire. I replaced the cable but it still does not work. I have read other posts that say it is either the turning gear in the housing that bolts onto the the diff. Its also suggested that it could be the part that sits in the gearbox, and the gearbox needs to be dropped to replace it. How does this all work/connect? E.g. the linkage between the gearbox and the housing on the diff.
Thanks.
Thanks.
Escortdriver1
Jul 31, 2015 02:36 PM
