Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus rs shafts on a normal 2.0 focus
Old Apr 14, 2014 | 07:19 PM
mk1 rob's Avatar
mk1 rob
Default Focus rs shafts on a normal 2.0 focus
Hi All, I'm putting the Focus RS gearbox into my 1998 2.0 Focus. It came with a pair of drive shafts and I dont have any normal 2.0 shafts to measure them against. So before I get frustrated with them not fitting can anybody let me know if they will fit or do I need a pair of standard 2.0 drive shafts?
Thanks in advance.
Rob
Old Apr 14, 2014 | 07:49 PM
leeby's Avatar
leeby
rs driveshafts wont fit unless you are using the rs wider track (they are longer from the gearbox to the end of the half shaft also the bearing on an rs is smaller than standard 2.0 ), and your 2.0 focus already uses the mtx75 gearbox but without the lsd
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
