Mk7 escort GTi brake conversion
Old Apr 13, 2014 | 03:58 PM
oldford10's Avatar
oldford10
Default Mk7 escort GTi brake conversion
I am converting the front brakes to cosworth calipers and discs but the carriers are hitting the ABS on the hubs. Can any one tell me if I need to change the hubs?
Old Apr 13, 2014 | 04:01 PM
STeve's Avatar
Super Moderator
cossie calipers are not suited to mk6 GTis really far better off with ones from a mk3 mondeo
Old Apr 13, 2014 | 04:05 PM
3i Jim's Avatar
3i Jim
10 Year Member
I had st170 brakes on mine. Pretty much fit straight on.
Old Apr 13, 2014 | 04:11 PM
STeve's Avatar
Super Moderator
that they do easier to find mk3 mondy ones though and use st170 discs
Old Apr 13, 2014 | 04:26 PM
oldford10's Avatar
oldford10
Thanks for the info but unfortunately I was told the cossy 4x4 fit straight on so I went and bought everything. I'll just have to remove the ABS system and put them on.
Old Apr 13, 2014 | 05:08 PM
STeve's Avatar
Super Moderator
I would send the bill to whoever told you they fit straight on and to remove abs for a set of calipers is stir crazy its only a gti after all
Old Apr 15, 2014 | 12:51 PM
oldford10's Avatar
oldford10
A GTI with 190bhp. I need more stoping power lol
Old Apr 15, 2014 | 01:01 PM
luke19790_3's Avatar
luke19790_3
What engine does it have?
Old Apr 15, 2014 | 01:16 PM
Paul_RS's Avatar
Paul_RS
Cosworth setup would be inferior to the st170 setup anyway.
Old Apr 15, 2014 | 01:56 PM
oldford10's Avatar
oldford10
1.8 zetec
Old Apr 15, 2014 | 02:07 PM
oldford10's Avatar
oldford10
When you say pretty muchfit straight on what do you mean? What has to be done to fit them and is it mk1 st170
Old Apr 15, 2014 | 04:18 PM
luke19790_3
1.8 zetec
What mods?
Old Apr 15, 2014 | 05:35 PM
STeve's Avatar
Super Moderator
st170 is only a mk1 facelift and the front brakes totally bolt straight on, the only job to do is simply widening the mounting hole which is very very easy and a 2 minute job unless you are clueless at car DIY
Old Apr 15, 2014 | 07:54 PM
oldford10's Avatar
oldford10
Originally Posted by luke19790_3
What mods?
130bhp head
4branch, straight through middle pipe to back box
iridium plugs with 10mm leads
R1 bike carbs
Old Apr 15, 2014 | 07:57 PM
bagginsRSturbo's Avatar
bagginsRSturbo
What management you running??
Old Apr 15, 2014 | 07:58 PM
oldford10's Avatar
oldford10
That I could manage that lol. Thanks for your help
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Old ford
Jul 31, 2015 06:50 AM
