Wheels and Tyres Wheels and Tyres for all Ford's
escort gti wheels on my mk 5 fiesta
Old Apr 13, 2014 | 03:41 PM
kaneferg_fezz's Avatar
kaneferg_fezz
Default escort gti wheels on my mk 5 fiesta
I have a set of escort gti alloys for my 2001 mk 5 fiesta but they hit my rear suspension, would I need spacers if so what size ?? The tyer size is 205/50 r16
Old Apr 13, 2014 | 04:00 PM
SmudgerByName's Avatar
SmudgerByName
Ford Fanatic
12.5mm are the norm when it comes to spacers on the rear. Try and get some axle spacers rather than hubcentric
Old Apr 13, 2014 | 04:13 PM
luke19790_3's Avatar
luke19790_3
They're mondeo alloys, tyre is also the wrong size
Old Apr 13, 2014 | 04:20 PM
kaneferg_fezz
What are axle spacers and do you need to declare them on insurance ??
Old Apr 13, 2014 | 04:27 PM
luke19790_3
Old Apr 13, 2014 | 04:51 PM
kaneferg_fezz
Originally Posted by luke19790_3
195 45
I was going to get low profiles so that should be okay
Old Apr 13, 2014 | 05:33 PM
bagginsRSturbo's Avatar
bagginsRSturbo
I would try out 195 tyres before you buy spacers imo
Old Apr 13, 2014 | 05:34 PM
STeve's Avatar
Super Moderator
as mentioned your using totally wrong profile tyres no wonder they are hitting as it has nothing to do with spacers etc, you need minimum of 45 profile ones either 195 or 205
Old Apr 13, 2014 | 05:38 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Yep. Take you hub to you local machine shop and have some spacers made for behind the hub carriers. With out getting technical, pack the hub face of the wheel out with washers until it doesn't rub, measure them and that's what you spacer needs to be.
Old Apr 13, 2014 | 05:49 PM
STeve's Avatar
Super Moderator
its not the wheel rubbing as mondy 16s fit perfect hes running wrong size tyres which is causing his issue so spacers are not needed
Old Apr 13, 2014 | 05:56 PM
DixieTheKid
Pick-up P100 Power!
Vincereese
Jun 1, 2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
