easiest way to take roof lining of my rs turbo
I would like to take the roof lining of my rs turbo s2 to see if there is any rust on the roof, what is the easiest way to get it off and is it an easy job to put back
steve
steve
You need to remove the 2 rear quarter glass windows also unscrew the handles in the roof ,remove the boot and door rubbers ,then peal the headlining away from the window and boot appertures carefully ,the rear of the headlining will then drop and you will see a metal rod (may be two metal clips holding it up remove these) ,you pull this to the front of the car and it will rotate down ,ease it out from one side and repeat the process on the other metal bars ,if you need to see more wind back the sunroof and remove the seal and the headlining around the sunroof can now come away,just reverse process to fit back in
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
