Rs s1 HELP I think it may be a ringer!
Old Apr 5, 2014 | 09:29 PM
DickyDumpValve's Avatar
DickyDumpValve
Default Rs s1 HELP I think it may be a ringer!
Hello everybody, I have just joined and this is my first question. I purchased an s1 a few years ago with intentions of a nut and bolt resto. I have eventually got round to stripping it bare but a few things just arn't right. Before I bury my hat in this I need to make sure I have the correct shell preferably the original would be nice. I know these quite well I think but as I have stripped the car I have notices it has had the roof skin changed at some point, didn't bother me to much as a good job, inner wing have been changed as well?? Me thinks a white pre 84 shell converted, it has rear roll bar long roof rails?. Does anybody know of any other tell tail areas, bulkhead etc something hard to change. it has a floor number but can't make out any letters even after paint stripperingthe paint off.Any guidance would be much appreciated. It Is a b reg custom by the way. The car is on the hpi register and may have had more hits than the Beatles but was not a real Rs without a bit of history. LOL!
Old Apr 6, 2014 | 06:09 PM
gtir1281's Avatar
gtir1281
a sure way is to check the ecu monting points
Behind the heater matrix box is the ECU. The fixings for this are unique to the S1 – the ECU screw-inserts are braized onto the bulkhead and are a gold colour, the same as the wing-to-scuttle panel. *note: if the ECU is fitted you will not be able to see this.
3i Jim's Avatar
3i Jim
10 Year Member
Does the chassis number stamped on the floor match the vin plate? Is there any sign of tampering on the floor?
Old Apr 6, 2014 | 09:08 PM
DickyDumpValve
Thanks for your replays, the chassis number is there but I can't make out any of the numbers at all, there is lots of surface rust as must have been holding water when stored. Will have a look at the ecu mounts for the captive nuts cheers. Many thanks. I have done some research and apparently the gearstick mounts are different and the rear seat mounts are different????? Don't know about them as I have checked and they look the same as my bro's mk4 any more suggestions ;(
Old Apr 6, 2014 | 09:12 PM
DickyDumpValve
Maybe I am just para about it may have just had rotten panels changed?? But the shell is solid and never welded anywhere else which is a bit odd? The car is B549 BYC is anybody has come accross it and can tell me anything?
Old Apr 6, 2014 | 09:14 PM
james kiely's Avatar
james kiely
has it a single or twin bolt setup on the front struts ?
Old Apr 6, 2014 | 09:15 PM
Fullflush's Avatar
Fullflush
If it's on the hpi maybe the roof was the repair? Or is it recorded stolen?
Old Apr 6, 2014 | 09:31 PM
RSI_TOM's Avatar
RSI_TOM
It was first registered on the 22 05 1985
It was lasted taxed on the 01 10 1996
You could also try the series one turbo forum aswell mate. Some one on there might know of it.
http://www.seriesoneturbo.co.uk/logi...7b95d0434fb64e
Old Apr 6, 2014 | 09:45 PM
DickyDumpValve
It has mk4 type strut tops but it looks like they have had work which is why I suspected an older shell especially when I can see it's had a roof skin. This work with no previous welding that I can see on the shell makes me sus? Don't get me wrong would make a good solid car but?? Was wanting to build something really nice even tho listed. So are there any other ways to tell if it was a pre 84 shell? Then I can make a decision in what I do or how much I spend in it?
Cheers guys
Old Apr 7, 2014 | 10:29 AM
DickyDumpValve
I am sure it is recorded stolen recovered? Cheers
Old Apr 7, 2014 | 07:24 PM
3i Jim's Avatar
3i Jim
10 Year Member
Have you got any pics of the suspect areas?
Old Apr 7, 2014 | 07:39 PM
3i-bays's Avatar
3i-bays
Its not showing on the s1 database, but i don't think Shawn has all of them anyway. Theres no different in the seats etc as my 3i is the same as s1.
Old Apr 7, 2014 | 10:41 PM
DickyDumpValve
Am working away in glasgow tomorrow until Friday , will sort some for the weekend so u can have a look.
Old Apr 7, 2014 | 10:53 PM
DickyDumpValve
Hi and thanks for looking for me, if your is an 86 3i as far as I am aware it would be the same as an s1. B C D maybe A reg. I am thinking maybe W X Y possibly A? Does that make sense? Cheers
Old Apr 7, 2014 | 10:55 PM
DickyDumpValve
What is the s1 database, who is Shawn
Old Apr 8, 2014 | 12:08 PM
gtir1281's Avatar
gtir1281
http://www.seriesoneturbo.co.uk/showthread.php?t=5
Old Apr 8, 2014 | 12:17 PM
gtir1281's Avatar
gtir1281
The front panel should have a cut out for the fan, it does look as though it’s had a bit just chopped out but that’s how it came from Ford. The grill should have black on the top and side edges – looking like it has been masked off, so if the grill is completely white it has been sprayed.
The front bumper is unique to the S1. It has longer studs and a spacer washer to push the bumper out more because of the arch extensions. Due to this the spot-light brackets are longer than non-S1 versions. The bumper plastics are also unique to the car as they are white plastic and not sprayed white.
the anti roll bar assembly which is different to S2 and normal Escort. There are two big cast pieces in the corners and there is a square box section piece behind the front bar. There are also clamps on the back of the assembly towards the wheels
The aperture for the rear opening 1/4 windows is also original to the S1 over the base Mk3 models. The S1 has holes for the hinges and locking clasps. Other mk3 models did not have these and will have been drilled into the shell - again you will only tell if this is stripped down
Old Apr 8, 2014 | 09:21 PM
DickyDumpValve
Hi and thanks for taking the time to reply. The car is fitted with s1 anti roll bar and has rear opening quarter windows, no spots fitted but I have purchased a mint set of carello 640's and brackets but now you say am not sure if they are s1 brackets, they are 81ag-15270-aa. Will need to check unless any knows if they are correct. If I can remember the window breakers where just screwed into the frame (b post) not sure if that's correct. If not then is not the real deal the front grill is all white with no black but not end of the world as prob had a slap or smudged lipstick at some point I would have thought cheers
Fil
Sep 30, 2015 12:08 PM
Aug 31, 2015 11:02 AM
zippyobrien
Aug 17, 2011 05:42 PM
