2009 1.6 tdci engine malfunction light
Hi new guy to the forum but in need of a bit of help and hoping 1 of u guys could help
Right here goes..... Last month I brought a 2009 1.6 tdci with engine in bits due to turbo fault. I have since replaced engine and turbo with a low mileage but after fitting it I drove 40 miles and 'engine malfunction' light came on so put it into fords to be on the safe side and they said it needed a forced regeneration of dpf. We'll after getting the car back again after 40 miles the same light came on so I had a m8 read the code for me and yep same code as before, so I bit the bullet and fitted a new dpf myself but still after fitting that the light still comes on with the same code
. The only way I can get the light to go off is to disconnect the wire going to the dpf pressure sensor clear the code and plug it back in then the car runs great
until I turn ignition off and restart it then the limp mode returns
So does any1 have any ideas I've tried replacing dpf pressure sensor with a second hand 1 but still got the same issue.
I'm now £3000 out of pocket with the mrs screwing and out of ideas
Thanks in advance
Flet3000
. So does any1 have any ideas I've tried replacing dpf pressure sensor with a second hand 1 but still got the same issue.
Thanks in advance
Flet3000
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
