Engine tempsensor
Old Apr 5, 2014 | 07:51 AM
Joycey85's Avatar
Joycey85
Default Engine tempsensor
The gauge on my dash don't work anymore can someone post a pic of it in situ and possibly a link to the correct part
Also is there any way to check it's this at fault
Old Apr 5, 2014 | 02:46 PM
xrmalin's Avatar
xrmalin
Might sound silly but is the sensor plugged in ?
You'll find it on the front of the cylinder head close to the thermostat housing it looks 13mm bolt head with a threaded stub on the end of it & off the top of my head so take this as gospel but I think it's a brown wire with a white stripe that goes on to the stub of the sensor.
Old Apr 8, 2014 | 06:22 PM
Joycey85's Avatar
Joycey85
Yeah mate found it and it was plugged in then I checked the wire for continuity and that was ok. I then touched the wire against a manifold stud and the gauge went up so would that point to the sensor itself? Thanks again
Old Apr 9, 2014 | 05:16 PM
xrmalin's Avatar
xrmalin
Give it a try it's certainly sounding like the sensor itself I think the sensors are only a couple of quid last time I bought one from the motor factors.
Old Apr 10, 2014 | 12:26 PM
martysmartie's Avatar
martysmartie
The sender is faulty.
Martin
Old Apr 12, 2014 | 04:39 PM
XR2's Avatar
XR2
There were different sensors available for the CVH engines. A Ford dealer will get you the right one by checking your VIN.
Old Apr 12, 2014 | 04:58 PM
GVK.'s Avatar
GVK.
Yeh, used to be different coloured sensors, all look and fit the same but there used to be coloured part between the stud and 'nut' part.
If the incorrect one is fitted the gauge reads all to piss.
Old Apr 12, 2014 | 06:43 PM
RSmark84's Avatar
RSmark84
Purple for the S2, I didn't know this years ago and fit a blue one. The reading was way to high.
MSD sell them for about £11 posted.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
