Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
St2 juddering under acceleration
Old Mar 30, 2014 | 09:07 PM
g1234's Avatar
g1234
Default St2 juddering under acceleration
As above car has started to judder/ shake while under acceleration like a wheel is buckled lol and common problems cause. This
Old Mar 30, 2014 | 09:32 PM
GVK.'s Avatar
GVK.
Could be a drive shaft issue, check wheels for buckles/out of shape tyres first.
Old Mar 30, 2014 | 10:13 PM
g1234's Avatar
g1234
Are shafts known for it
It feels like somethin unbalanced on acceleration
Old Mar 30, 2014 | 10:20 PM
SyRexx's Avatar
SyRexx
are you gassing it on a slippy surface? ESP judders/makes the car shake under hard acceleration
check the shafts/drivers side CV joints, they are common issues
Old Mar 30, 2014 | 10:53 PM
dodge8283's Avatar
dodge8283
Just had a very similar problem mate, turned out to be the drive shaft.
Old Mar 30, 2014 | 11:22 PM
g1234's Avatar
g1234
It's in all gears heavy acceleration even 60mph up so can't be esp trying to kick in
Old Mar 30, 2014 | 11:23 PM
g1234's Avatar
g1234
What's best way to check shafts I know if it's a cv it will have play in it but shafts I'm unsure
Old Mar 31, 2014 | 04:37 PM
st3v3's Avatar
st3v3
more than likely shafts
Old Mar 31, 2014 | 05:15 PM
g1234's Avatar
g1234
How can you check shafts ?
Anywhere sheffield area any good to suggest to go to
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
landaqmabba
Sep 15, 2015 07:16 PM
Marino
Sep 12, 2015 11:10 AM
