Cosworth Amal Valve
Old Mar 30, 2014 | 08:57 PM
cossie891's Avatar
cossie891
Default Cosworth Amal Valve
I converted my 3 door to L8 a few weeks back and all has been fine today I changed the inlet to a 4x4 now my amal valve is clicking like mental its flat out and clicks faster the more its revved
Any ideas guys?
There isnt any trapped wires by the way
Old Mar 30, 2014 | 10:45 PM
martysmartie's Avatar
martysmartie
You have interfered with the TPS...
Martin
Old Mar 31, 2014 | 06:39 AM
William MK2 Cosworth's Avatar
As above, I would check the tps first. The only good thing I have found, there are not a lot of things to go wrong electrically, and all you have to do is start at the last thing you have altered. After that give a check to all the connectors under the inlet incase something else has moved out of place
Old Mar 31, 2014 | 08:21 AM
cossie891's Avatar
cossie891
Ok cool will go and have a look later today
gchristophi
Aug 31, 2015 10:36 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
muffster
Aug 11, 2015 05:39 PM
jdsjojo
Aug 1, 2015 08:50 PM
