Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
1999 focus diesel heating problem
Old Mar 30, 2014 | 08:45 AM
tonysierra4x4's Avatar
tonysierra4x4
Default 1999 focus diesel heating problem
can anyone tell me why the heater blowers won't work on a focus diesel bought as a run around by my son. i have checked fuses and relays (i think i've checked the right ones). where else would i start looking before i get to stage of taking motor out. thanks. the air con light is on if that helps.
Old Mar 30, 2014 | 08:54 AM
Colin_P's Avatar
Colin_P
Quite a common one is the resistor pack failing but leaves it working but only on speed 4.
If it is not working at all then as you've done, fuses (I'm not sure which one) or the motor itself.
Old Mar 30, 2014 | 09:16 AM
tonysierra4x4
thanks colin, will do some investigation before i attempt removal of the blower motor.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
