RKK.. S2 RST .R.I.P NEW S1 PROJECT. LGP(16/08/05)
well the head gasket has had a small leak for a while now.. so decided it was time to sort it out...
also got a new exhaust to fit too, but the exhaust nuts decided to be rounded off... thank god for a grinder..
how it looked to start with...
started stripping.. GRS off.. rad.. pipes.. etc....
top part of inlet off..
next part.. rocker cover off.. head looking nice and clean!!!
head next off.. and a loook at the pistons..
still awainting a few more parts.. so got a bit more involved last night..
will get a few more pics today as camera batt died.. but decided to tidy both looms.. a spray a few bits of the bay... proper diy style..
bays very empty.. blocked painted..
will update again tonight...
more work done today...
this is how it looked when starting out..
block painted black.. this was a picture of the first coat.. 1 more been added and looking much better...
the gearbox to be painted..
some paint work on the front freshly sprayed..
inner wings
the loom having the mfi parts cut out...
the top part of the inlet.. sprayed black..(EFI is silver.. but left masked)
turbo cleaned up with a wire brush...
that for today.. hopefully carry on tomorrow...
inner wings
update time..
sprayed a few bits today.. alt bracket.. amal valve bracket.. etc
painted this one..
cleaned alternator..#
throttle body..
starter motor..
loom re taped and re fitted..
indicators and headlights back in.. and done for the day..
painted this one..
throttle body..
starter motor..
well managed to get some work done today,,,,
new parts arrived!!!!all for the headgasket!!thermostat.. cam belt...
managed to get a load of bit`s of jano this week.. cheers jano!!!
new throttle cable.. bracket.. gasket as needed to turn the throttle body over and also to fit me new rocker cover...
my inlet anf throttle body...(needin a ISCV ANYONE????
sprayed the bar map sensor braket and throtle cable bracket..
also new fuel filter to remove all the old k-jet fuel parts...
again cheers jano for the parts!!!!
also needed to clean the rear of the engine bay... was thick with dirt and was geting nowhere with a clothe and elbow grease!!!
so soaked the lot in TFR... AND GOT THE JET WASH OUT!!!
THE RESULT WERE IMPRESSIVE!!!
and how it looked when i gave up for the day!!!
and last ... one new thing for the car!!!
brand new... an e bay bargain!!!!
Originally Posted by adamS2RST
All looks good mate will we see her on wednesday?
Originally Posted by twins
Coming on really well ,how much was the heater switch panel
Originally Posted by Hartyboy
what did u clean the back of the engine bay with TFR???? whats that
great on wheels etc too.. proper product!!!!
all at a better price that if i go to the local ford parts store!!!
fill in a on line order... they give ya a quote!!!!
or e mail trevor porter!!!
i paid Ł120 plus delivery for the lot!!!
well managed to get some more done today...
started to add the wiring back to the car.. alternator and starter motor
new fuel filter fitted!!!
a few more pipes and cables refitted!!!
head back on!!!
.. new cambelt.. ford headgasket and head bolts
new black rocker cover fitted!!!
turbo re fitted!!!
just loom.. water pipes rad cooler to go!!!
head back on!!!
turbo re fitted!!!
Looks minted mate, well done
Anyone got a list of parts needed for converting to EFI and a rough cost for everything!? i badly need to sort the wiring for my headlights etc its a mess! another job! lol
well things a really comming together now...
been at work on it all after noon so a few pics of the progress...
how it`s looking now...
pipes rad cooler,, etc back on!!!
loom back in place!!!
new ford leads and plugs fitted too!!!
sorted me throttle issue... cheers jano..
just awaiting some parts for the throttle body and should see her running!!
