What T3 Turbo is this?
Old Mar 26, 2014 | 11:46 AM
HaggisTurbo's Avatar
HaggisTurbo
Default What T3 Turbo is this?
Been offered a T3 Turbo which as the following spec:
.42 Compressor Side
.48 Exhaust Side
360 Degree Thrust Bearing,
I believe it's from a cosworth, would this fit a Escort for a Zetec Turbo build and Would this flow the same as a stage 3 Erst T3?
Thanks
Old Mar 26, 2014 | 01:17 PM
mgtkr1's Avatar
mgtkr1
yea essentially a 4x4 cosworth t3. be good on a zetec turbo with quick spool up. what size is the compressor wheel?
Old Mar 26, 2014 | 01:28 PM
HaggisTurbo
Standard to my knowledge mate.
You reckon this would flow for 300 ish bhp?
Old Mar 26, 2014 | 01:47 PM
mgtkr1's Avatar
mgtkr1
yea should just about do 300bhp on a zetec.
Old Mar 26, 2014 | 01:56 PM
HaggisTurbo
Would it be running at its limit on 300 though or a little extra room? Also would it bolt onto the RST Manifold or am I going to have so swap some parts over?
Old Mar 26, 2014 | 02:04 PM
mgtkr1's Avatar
mgtkr1
id think it would be close to its limit but the spool up time will be as good as you could hope for with a t series turbo. it will bolt onto a rst manifo I have the same turbo on a 1600 and its not really laggy. on a 2.0 it will be spot on
Old Mar 26, 2014 | 02:20 PM
Canada1's Avatar
Canada1
Do you have a picture of the compressor side opening?
You will need to know what size the compressor is - 45, 50, 55, or 60 trim.
One needs to measure the compressor inducer size.
You have the turbine size of .48, good for 300 hp (maybe more in some cases.)
The compressor side will tell you the maximum HP capable.
One could have a 45 trim compressor with the .48 housing. This would be laggy and maybe support 230 hp.
Old Mar 26, 2014 | 02:53 PM
HaggisTurbo
Canada,
These are the only two pics I have this one is 2wd with 42/48 and a 360 thrust bearing
I also have the chance at a stage 3 t3 from a 4x4 Cossie
Man this is complicated ahhaha
Attached Thumbnails What T3 Turbo is this?-_12.jpg   What T3 Turbo is this?-_12-1-.jpg
Old Mar 26, 2014 | 03:00 PM
RUBY123's Avatar
RUBY123
looks like a 4x4 turbo
Old Mar 26, 2014 | 04:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
How can you tell that? lol Could have any size comp wheel in that 42 AR housing!
Exactly.
It does indeed, the two actuator bracket bolt holes in the comp housing give it away.... .48/60
Old Mar 26, 2014 | 06:08 PM
HaggisTurbo
Here are the rest of the pictures of it,
Guy reckons it came off a 2wd is this pretty definite a 4x4 one?
Hope it is would be ideal!
Attached Thumbnails What T3 Turbo is this?-_12.jpg   What T3 Turbo is this?-_12-4-.jpg   What T3 Turbo is this?-_12-3-.jpg   What T3 Turbo is this?-_12-2-.jpg   What T3 Turbo is this?-_12-1-.jpg
Old Mar 26, 2014 | 06:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
2WD doesn't have actuator bolt holes in the comp housing.... but that's not to say it wasn't fitted to one.
Old Mar 26, 2014 | 06:28 PM
HaggisTurbo
Ahh nightmare lol. The 4x4 one better specc'd I take it?
Guy also mentioned it has had a 360 thrust bearing fitted.
Does this make it a stage 2 4x4?
Old Mar 26, 2014 | 07:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Will flow a little more BHP yes, the 2wd has a smaller comp wheel (50 trim IIRC, could be 55).
It just means it will last longer, stage 1 you might say as it won't actually produce any more power than a standard one.
Old Mar 26, 2014 | 08:10 PM
HaggisTurbo
Thanks Karlos, Is a standard 4x4 T3 the same as a Stage 3 RST One then?
Old Mar 26, 2014 | 08:42 PM
HaggisTurbo
The guy has done some measurements for me. Does this clear up what it is?compressor measures 5.5" with a 2.5" intake and a 2" out to intercooler
Old Mar 26, 2014 | 10:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No, it's close but the 4x4 has a better flowing exhaust housing (both .48 though) and a larger compressor wheel.
lol No, that's the dimensions of the housing.
Old Mar 27, 2014 | 01:13 AM
HaggisTurbo
Part number is TB0384,
Think Im going to buy it if it makes similar power to a stage 3 t3 erst turbo
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
