Escort RST Series 2 manual fan switch wiring help needed
Old Mar 23, 2014 | 04:54 PM
webbie227's Avatar
webbie227
A Webb
Default Escort RST Series 2 manual fan switch wiring help needed
Hi all
I have fitted 2 10inch fans onto my radiator and I want them on a manual switch on the dash
My questions are... what is the best way to go about doing this, what gauge cable do I need? What amp fuses? And do I need a relay? And if so what amp and how do I wire it all up?
Many thanks
Old Mar 23, 2014 | 08:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Why on a switch mate? Better to have them come on automatically when they should, no risk of forgetting to turn them on! lol
If your getting too hot and are thinking about turning them on early then you have other problems to sort out.
Old Mar 23, 2014 | 09:06 PM
GVK.'s Avatar
GVK.
Agree with that.
There's a recent good post about wiring up twin fans properly on here.
Old Mar 23, 2014 | 09:15 PM
GVK.'s Avatar
GVK.
https://passionford.com/forum/techni...oling-fan.html
Use the link posted by turbosystems NOT the notepad sketch!!!
Old Mar 24, 2014 | 09:10 AM
muz's Avatar
muz
Wye Valley Hardcore
Do as I've done. Keep the standard set up with a manual over ride switch. Fan will then come on as it should as normal but can override it to come on early. To be honest, if the cooling system etc is all up to scratch you shouldn't ever need it.
Old Mar 24, 2014 | 10:20 AM
webbie227's Avatar
webbie227
A Webb
Cheers everyone, I will give it a bash today, much appreciated
Billy_RS
16
Oct 11, 2025 09:41 PM
col93saphcos
Aug 7, 2015 03:21 PM
dlwarrior
Aug 5, 2015 10:19 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
