Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
1.3 to 1.7 engine swap MK5 fiesta
Old Mar 22, 2014 | 09:46 PM
Prickly_buzz's Avatar
Prickly_buzz
Default 1.3 to 1.7 engine swap MK5 fiesta
In planning to do the popular puma conversion on my mk5 '51 plate fez.
It's a 1.3 HCS I have read as much as I can find online but it's mainly based on people going from 1.6 zetec to the puma lump so thought id ask if anyone had any advice for me going from my 1.3 engine.
Is there any difference in gearbox mounts or gearbox ratios etc I.e do I need a puma/1.6 fez box?
I've heard the driveshafts need to be changed - something about them being too short and popping out on full lock?
The fuel lines - are these going to be ok for the puma lump as I know the 1.6 ones fit but have to be re-routed.
Also the PAS pipes do these need changing or are all fez ones the same regardless of engine?
Old Mar 22, 2014 | 09:52 PM
bagginsRSturbo's Avatar
bagginsRSturbo
The conversion is straight forward drive shafts are ok as are the fuel pipes just need the loom abd ecu quite simple really
Old Mar 22, 2014 | 10:37 PM
lacey's Avatar
lacey
I have a zetec s done good fun , shell has seen better days lol but the rest is still of if you want it cheap ?
Old Mar 23, 2014 | 08:51 AM
Prickly_buzz
Just had a thought, what I said about the driveshafts had to be rubbish because if I'm using the same g/box how could the driveshafts possibly be a problem?!
Old Apr 11, 2014 | 09:51 AM
Prickly_buzz
Ive been doing a little more research on what i need, unfortunatley I dont have the luxury of space so buying a donor car isnt possible and seeing as this is my only motor at the moment im going to need to make sure I can get it all done in a few days but as far as I can tell its a pretty fool proof conversion.
I have worked out that i need the following:
  • Engine (obviously)
  • Gearbox - 1.6 or puma
  • Driveshafts - Any zetec fiesta or puma
  • Air-box
  • Maf sensor
  • Front fuel pipe sections (these are joined to the rest of the fuel line near the bulkhead somewhere so only need the front)
  • All coolant hoses - from any zetec fez or puma
  • Radiator - 1.6/puma
  • Gearbox Mount - Puma
  • Top engine mount - Puma
  • Throttle cable
  • Engine loom
  • ECU
  • Key chip & Transponder ring
  • Exhaust Manifold/Cat - 1.6/puma
Please let me know if theres anything ive missed or anything i dont need from my list!
Old Apr 12, 2014 | 12:02 PM
7sean7m7's Avatar
7sean7m7
Some upgraded brakes and suspension!
Old Apr 12, 2014 | 12:35 PM
Prickly_buzz
Hahaha, yea goes without saying, the brakes arnt good enough for the 59 bhp its got now!
Old Apr 23, 2014 | 10:26 PM
Prickly_buzz
Had a thought - I intend on not running A/C as my car dosent have it anyway. My question is how do I go about finding a belt to run the AUX side of things on the engine because a normal puma 1.7 belt won't fit once I remove the A/C compressor.
Old Apr 24, 2014 | 05:08 AM
bagginsRSturbo
You need a non air con power steering pump and pipes which you should have on the 1.3.
You mount it on the front instead of the back so you also need a non a/c aux belt hope that helps
Old Apr 24, 2014 | 05:09 AM
bagginsRSturbo
Like this
Old Apr 24, 2014 | 12:39 PM
Prickly_buzz
Ahh! Brilliant, is there a puma which ran no a/c?
If not which belt would I use?
Old Apr 24, 2014 | 12:49 PM
Prickly_buzz
Also any ideas which ECU I need to use? I know it has to be from a 'digital build car' but I've heard there's a few which are more ideal for the fiesta for some reason.
Personally I just want the MUFF ECU.....
Old Apr 24, 2014 | 01:01 PM
jam53ice's Avatar
jam53ice
I have some 260mm ZS calipers if your interested bud
Old Apr 24, 2014 | 03:40 PM
bagginsRSturbo
Ise you fiesta powersteering pump amd buy a non air con aux belt for a puma.ecu you want tape for pops and bangs lol
Old Apr 24, 2014 | 04:43 PM
Prickly_buzz
Ahh really wanted MUFF lol why does TAPE have 'pops and bangs' something to do one lambda sensors?
Old Apr 24, 2014 | 04:49 PM
bagginsRSturbo
It will help with only having one lamba so wont throw up eml, the pop and bangs will happen on overrun
Old Apr 27, 2014 | 07:38 PM
Prickly_buzz
Sounds pucka, I'll be adding that to the list of parts I'm hunting down, still need most bits bit wanna get the lump sorted first really because don't know what I'll be getting with it.
Old May 2, 2014 | 09:09 AM
Prickly_buzz
Been thinking a bit more about this conversion and i have yet more questions which hopefuly somone will be kind enough to answer!
1. Whats involved in sorting out the fuel lines, can i just buy the front section of the puma (engine bay) pipes because it looks like the join to the rest of the fuel line just underneath the bulkhead area on ecat.
2. The 'TAPE' ecu which i have been told i need, is this ok to run the digi version (mines 2001 reg)
3. Obviously i will be adding the white digi dials as i currently have no rev counter or temp guage and a lovely picture of a car. I need to know if this is just plug-and-play or do i need to re-wire cirtain things?
4. Understand theres something i need to do with the puma loon regarding two multiplugs being incorrect for the reverse light switch however if i am using a puma G/box this should plug straight in surely?!
JoeyBoyden
Jan 4, 2024 02:36 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
vdubo7
Aug 2, 2015 08:17 PM
