Sierra Sapphire RS Cosworth 90' H Reg 4x4
Old Mar 22, 2014 | 05:41 PM
Gaz_93's Avatar
Gaz_93
ST!
Default Sierra Sapphire RS Cosworth 90' H Reg 4x4
Here I have for sale is my Sierra Sapphire RS Cosworth Registered 1990 on a H Reg an Early 4x4 in rare Flint Grey.
She's currently sitting on 122k with 1 months tax. Full Service History and MOT History and a folder stack full of other history and parts history.
Comes with Full Recaro Leather, Heated Screens front and back, electric windows all round, electric wing mirrors. She's running Stage 1 unsure on chip i think it was a custom chip by a company called Interpro in Bristol and had alot of worked carried out by them also which you can see in the History.
Various Samco Hoses, K&N Group A Filter, Group A Coil, Motorsport HT Leads, Scorpion 3.5 inch Full exhaust with rolled tip. She Recently had a fair few parts spent on her 2 weeks ago which consisted of:
Gates Timing Belt and Tensioner
New Tappets/Lifters
Rocker Cover Gasket
New Cam seals and Nose seals
Rotor Arm
Phase Sensor
Distributor Cap
Oil Change With Millers 10w/60 With EFL90 Motorcraft Oil Filter
New Rocker Bolts
New Fuel Pump
She's fully undersealed underneath an very strong only two patch's of welding in the past by the transmission tunnel where the gearbox must of rubbed by a failed bush in it's previous life and by the rear passenger floor pan. Done to a high standard and no snotty welding. RS7 Softlines wrapped in Falkens and Yoko's on rear.
Fully Polybushed on the Front end apart from engine mounts. Fairly New Shocks and Eibachs springs which were on when I bought the car. Airtec Radiator also. She has the original engine bay stickers and on the original intercooler. She has had replacement wings in the past with genuine wings previous owner ran 19's and had it lowered as you can imagine the arches took a whack which was a done thing back in the day. Interiors pretty solid seats are very good in the front rear bench is almost like brand new. headlining sagging a tad in the rear but nothing major it is 24 years old. She's a very good example for her age. Still have a original Lattice spare wheel with the foam inserts. Also have a few parts i can give with her.
New Car is on order which is forcing the sale i'm looking for a quick sale also. Bad bits would be there is some slight bubbling on the rear arches which is common and again it is 24 years old but nothing too major an not noticeable unless looking from underneath and some slight bubbling in the sunroof area but again she's an old girl. other niggles ABS Light pops up from time to time the sensors have been changed, probably needs cleaning up again. Electrically everythings sound everything works how it should. I'm sure i've missed a few bits. Can appreciate the pictures aren't that good I can only apologise.
Anyway I'm After £6,800 Open to Sensible offers Quick sale needed.
07897163094.
Harlow, Essex.
Size:  430.4 KBName:  56FBFCF4-EB4F-4080-9F53-F3FE1E734D04_zpsan5gjmvk.jpg
Old Mar 23, 2014 | 01:39 PM
Looks a nice car matey. I hope it goes to a good home.
Old Mar 23, 2014 | 03:36 PM
Gaz_93's Avatar
Gaz_93
ST!
Thanks mate sorry to see her go, just new car forces sale now dude quick sale needed really lol
Old Mar 24, 2014 | 07:57 PM
Gaz_93's Avatar
Gaz_93
ST!
Bump. Quick sale intended, Being moaned at by the Mrs!
Old Mar 24, 2014 | 08:32 PM
r5matt's Avatar
r5matt
What car you getting Gaz... ? You never said
Old Apr 1, 2014 | 04:32 PM
Gaz_93's Avatar
Gaz_93
ST!
I'll let you know on Facebook matt, and She's still here bumpty
Old Apr 8, 2014 | 12:07 PM
cossietim's Avatar
cossietim
C10 OSY
very clean, hope it goes soon for you, a real collectors item
Old Apr 18, 2014 | 05:58 PM
Gaz_93's Avatar
Gaz_93
ST!
Bump Price drop £6,400
Old Apr 22, 2014 | 04:24 PM
Gaz_93's Avatar
Gaz_93
ST!
Drop to £6000 needs to be gone this week, deposit is now due many thanks
Old Apr 22, 2014 | 04:37 PM
LHD220Turbo's Avatar
LHD220Turbo
to help your sale, youy may want to mention if its ever had a documented engine rebuild? i assume its on a 200 block?
SmudgerByName
52
Jul 28, 2016 06:14 PM
RB26DETT
17
May 27, 2016 11:26 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
pegaz
Aug 12, 2015 07:30 AM
Old ford
Jul 31, 2015 06:50 AM
