Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
fiesta mk4 bigger front disk conversion
Old Mar 20, 2014 | 06:29 PM
SJBRYANT's Avatar
SJBRYANT
Default fiesta mk4 bigger front disk conversion
I'm looking at converting my front disk and caliper to a bigger size what do I need
Old Mar 20, 2014 | 06:34 PM
bagginsRSturbo's Avatar
bagginsRSturbo
depends on what you want you can use the mondeo 300mm brakes all you need is the discs and calipers, also depends what size wheels you have as you may need to trim the calipers down
Old Mar 20, 2014 | 06:47 PM
SJBRYANT's Avatar
SJBRYANT
I've got 17s.on
Old Mar 20, 2014 | 06:54 PM
bagginsRSturbo
ok you'll be alright then
Old Mar 20, 2014 | 07:02 PM
cos 4x4's Avatar
cos 4x4
Go in the zsoc and see big g 1985 on there he sells the full conversion with all new bolts discs and pads and used calipers
Old Mar 20, 2014 | 07:13 PM
SJBRYANT's Avatar
SJBRYANT
I work in a car parts shop so if I know the engine size and yr of the caliper of the mondeo I can get them but there's that many different disks and calipers for each Mondeo so I need to know which mondeo specifically
Old Apr 7, 2014 | 08:10 PM
Straight_4_N/a's Avatar
Straight_4_N/a
Focus st170 discs.
ford mondeo mk3 calipers and brake pads
or
focus st170 calipers and brakes pads.
all mondeo mk3 run the same brake pad fitment yes I know theres two listed but both are the same.
also wouldn't touch big g with a 10 foot pole £165 for a £60 kit
JoeyBoyden
Jan 4, 2024 02:36 PM
C2 MAK
Aug 20, 2015 09:46 PM
A.t.p
Aug 15, 2015 11:37 AM
Botts
Aug 13, 2015 04:16 PM
