Which EFI Flywheels Can I use?
Old Mar 19, 2014 | 04:47 PM
HaggisTurbo's Avatar
HaggisTurbo
Default Which EFI Flywheels Can I use?
Hi All,
Doing the ST170/Blacktop Zetec Turbo conversion and I am having some trouble sourcing an EFI flywheel.
Is it just the Fiesta RS Turbo one I can use or can i use the Zetec RS1800 one? or the xr2i one? or even an xr3i 16v?
Are they all the same or is it only CVH one I can use.
I am mating it to a Ka Gearbox hence the need for the flywheel
thanks
Old Mar 19, 2014 | 06:05 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Any EFi cvh item should be fine
Old Mar 19, 2014 | 06:10 PM
xrmalin's Avatar
xrmalin
But if you use a cvh flywheel you'll have to open the mounting bolt holes up by a mm or so so that the Zetec bolts fit through it
Old Mar 19, 2014 | 06:24 PM
studabear's Avatar
studabear
1.8 focus petrol flywheel Im sure I've read that it fits, no drilling either.
Old Mar 20, 2014 | 01:22 PM
HaggisTurbo
My query was because Its an ST170 bottom end so I would have thought any zetec 2.0 litre flywheel would have done, connecting to an ib5 ka box? Or is there a specific reason it needs to be a CVH one? Confused.com lol
Thanks for your help folks
Old Mar 20, 2014 | 01:41 PM
studabear's Avatar
studabear
2litre focus had a mtx box 1.8 had ib5
Old Mar 20, 2014 | 07:18 PM
xrmalin's Avatar
xrmalin
The cvh flywheel is lighter too
Old Mar 20, 2014 | 09:36 PM
studabear's Avatar
studabear
A few efi 2i/3i cars on ebay for breaking, might get a flywheel from one of them?
Old Mar 21, 2014 | 12:37 AM
HaggisTurbo
Hi Stu got a Flywheel from a 1.8 Xr2i 16v which had a ib5 gearbox.
Old Mar 21, 2014 | 09:05 AM
Karlos G's Avatar
Karlos G
Balls Deep!
This.
Should be fine then, you use an RST clutch too which is why a 220mm flywheel is also needed.
Old Mar 21, 2014 | 12:00 PM
HaggisTurbo
Yup just need to organize a clutch and I can start building it all up.
Going to give it a good clean and a paint first though
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
