Focus st170....Problem's etc
Old May 9, 2004 | 06:36 AM
j.w's Avatar
j.w
Default Focus st170....Problem's etc
Hi, thinking of purchasing an st170 engine loom and ecu as a conversion, has anyone experienced any problems with their engines? i have found an engine with 3000miles on, also does the haynes cover the st170? i.e wiring diagrams etc?
just wanna know as the cheapest engine loom and ecu i have found is gonna set me back £1850
Help appreciated, jeff
Old May 10, 2004 | 04:54 PM
j.w's Avatar
j.w
Old May 11, 2004 | 02:41 PM
MarkyMark's Avatar
MarkyMark
Try shop around mate, know you can get that elsewhere for cheaper
Does that price include the gearbox?
Old May 11, 2004 | 06:01 PM
j.w's Avatar
j.w
no mate, im a bit unsure about the gearbox fitting as its going into a mk6 escort
Old Jul 20, 2004 | 01:49 PM
gatekeeper's Avatar
gatekeeper
Default st170 conversion
hi,the st170 calibration require all the units the vehicle was originally built with be connected.if this is not done the ecu slowly derates the system and you will continually loose performance.you will also need to use the same gearbox as a change of gearbox requires certain flags to be set in the ecu.again if this is not followed you will encounter a reduction in performance.depending on what you are building you may find the 2.0lr-tr focus package may be the more economical package to build with performance of up to 180bhp can be gotten with little change of mechanical parts and the right ecu.
please give me an idea of what you are building and i will tell you which way to go.
gatekeeper
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
