Series 2 RS
Queries guys I'm lookin help with:
No.1 Had the battery disconnected for 24 hrs,reconnected it to take the car for a spin and discovered the speedo wasn't workin........Any ideas ?
No.2 Will 17s fit rst s2(standard ride height) without any arch adjustments.
Cheers guys.
Cheers guys.
your speedo works via a cable from your gearbox to yuor speedo so disconnecting your battery will not affect it. Was it a little bit jumpy before, needle not moving as smooth as it should. Usally a sign of cable failure.
I have 17's on mine with no arch mods and a 20mm drop and it causes no problems or me.
Hope this helps
Hope this helps
Thanks for the reply mate. I've got is sussed.Was fiddling with rear demister switch and musta hit the cable.Did a bit of pushing and shoving and its ok. Now I can take it for a blast.
17's no trouble.............I think a purchase of wheels is in order then
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
