boot light switch.
Old Mar 16, 2014 | 03:12 PM
Chopshop85's Avatar
Chopshop85
Default boot light switch.
What dictates the boot light coming on in a mk4 escort?
When I open the boot the light flickers as the boot goes up and it causes my sub to pop?!
Old Mar 16, 2014 | 07:58 PM
RSmark84's Avatar
RSmark84
There's no boot light switch, when you turn the sidelights on the boot light and number plate light comes on too.
Old Mar 16, 2014 | 08:00 PM
GVK.'s Avatar
GVK.
I thought they had a 'mercury' switch in the tailgate, so when the tailgate gets a certain angle the switch activates and puts the light on.
Old Mar 16, 2014 | 11:47 PM
Chopshop85's Avatar
Chopshop85
My boot light comes on when the tailgate is lifted about an inch?
Someone said this to me earlier, but I would have no idea where it is or what one even looks like?!
I should think if it was broken or had a bad connection this would cause the light to flicker on and off.
Old Mar 16, 2014 | 11:48 PM
martysmartie's Avatar
martysmartie
There will be switch on the lock, if like other setups.
Martin
Old Mar 16, 2014 | 11:50 PM
martysmartie
Originally Posted by Chopshop85
Someone said this to me earlier but I would have no idea where it is or what one even looks like?!
Whatever type of switch it has, the problem is it's not making good contact!
Martin
Old Mar 16, 2014 | 11:52 PM
Chopshop85's Avatar
Chopshop85
Might have to whip the lock mechanism out and have a look.
When I rebuilt the boot I cant remember any wires going to it though.
Old Mar 16, 2014 | 11:56 PM
GVK.'s Avatar
GVK.
IIRC the 'mercury' switch is a gold/brass coloured 'tube' shaped thing with a wire coming out of it, it's in the tailgate.
Can't find any pics of one though.
Old Mar 16, 2014 | 11:59 PM
Chopshop85's Avatar
Chopshop85
I will have a look tomorrow.
Its no big deal. The issues come to a stop by removing the boot light bulb (which is about as useful as a match ember), however I do like to fix things rather than leave them.
Old Mar 17, 2014 | 12:05 AM
GVK.'s Avatar
GVK.
I'd check the wires from the roof to the tailgate as well, as these were very common for breaking back in the day.
I'm intruiged about the boot light switch now, if you do find it, can you put a pic on here please?
Old Mar 17, 2014 | 12:11 AM
Chopshop85's Avatar
Chopshop85
Yeah I did consider the wires from the roof through the tailgate, however the flickering issue only occurs when the tailgate is about 2/3 open. If you wiggle it up and and down slightly then the light flickers. Gave all the wires from the roof a good wiggle and that has no affect.
I'll get some pictures of my findings
I still cant understand why its making my sub "pop". The sub is wired to the amp, which is wired straight to the battery and earthed to the boot floor. I always knew electric was some kind of magic
Old Mar 17, 2014 | 12:22 AM
GVK.'s Avatar
GVK.
Some kid of interference going on, must be!
Found a PDF of the Haynes book of lies, it mentions the 'load space lamp switch' but no pic of it, and the text just says to remove the trim in the tailgate, remove a screw and remove the switch.. that's it
Page 4 on here - http://escort.mk3.pagesperso-orange....es/0686-12.pdf
Old Mar 17, 2014 | 05:47 PM
Chopshop85's Avatar
Chopshop85
This is the switch.
and with the latch closed
So it just breaks the circuit once the boot is closed.
Old Mar 17, 2014 | 06:03 PM
GVK.'s Avatar
GVK.
Well that's my theory out the window then.
Old Mar 17, 2014 | 06:09 PM
Chopshop85's Avatar
Chopshop85
I checked the wires going from the boot to the roof and one of them was very flexible. Ended up chopping out the soft section and reconnecting it.
The boot light is now on, nice a bright until the boot is fully open, then the light goes out and the sub goes "pop"
So I'm still confused about this.
Old Mar 17, 2014 | 06:37 PM
Chopshop85's Avatar
Chopshop85
Just had a thought on this. Where the tailgate meets the roof, should this be a bare metal join? as the tailgate doesnt have an earth strap.
Old Mar 18, 2014 | 02:14 PM
martysmartie
It's clearly the wiring at fault.
Martin
Old Mar 18, 2014 | 04:40 PM
Chopshop85's Avatar
Chopshop85
Yup. Ended up rewiring the back of the switch into the car to a point where the wires dont move. Problem solved.
gcfcos
88
Sep 15, 2015 03:48 PM
The Enigma
Sep 12, 2015 10:12 PM
chris m1
Sep 7, 2015 08:02 PM
fuzzy
Sep 4, 2015 10:11 PM
