Fuel Pump Loom
Right guys - got my new fuel pump wiring loom. Had a look at the car this evening and have a question.
The new loom has round spade connectors at pump end. I would have thought they would be bullet type, that would push onto the terminals of the pump. What is the best way to make connection?
However if you connect up directly, you be will bypassing the cutoff switch in boot, which probably is not the right thing to do.
What is the right way to do this?
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
