loom plugs
Old Mar 9, 2014 | 08:49 PM
paddy heffernan's Avatar
paddy heffernan
heffo
Default loom plugs
right lads i need to swap two wires on on throttle position sensor plug how do i pull pins back out of plug without breaking them.
Old Mar 9, 2014 | 08:52 PM
cossie330's Avatar
cossie330
You can buy special tools for that, i think Durite make them
Old Mar 10, 2014 | 06:47 PM
pectelboy's Avatar
pectelboy
I have a lead made so you don't have to touch them ,just plug it in and away you go , think I've got another one
Old Mar 10, 2014 | 07:06 PM
oldford's Avatar
oldford
I use a small paper-clip for these kind of connectors.
Old Mar 10, 2014 | 11:50 PM
paddy heffernan
heffo
had a go at pulling out pins and the broke so I cut plug off old loom and soldered to new loom .thanks for replies
Old Mar 11, 2014 | 11:58 AM
delbee1's Avatar
delbee1
Pretty sure these should be crimped mate as the solder can affect the voltage read from the sensor at the ecu, ford made repair kits which were the connector with pig tales to join to old loom, these had crimped splices and heat shrink to connect and werent soldered.
Also solder tend to break loose under vibration
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
muz
Sep 30, 2015 08:29 AM
deathrider666
Sep 28, 2015 06:12 PM
