4x4 rear ARB to 3dr
As title what's involded in fitting an ARB from either sapphire or escos to a 3dr?
I know the trailing arms have different pick up points but other than that what are like at mounting to the body?
And anyone with a supra diff how did you get on fitting as that's what diff I have in mine
the later arb mounts are welded onto the where the brake pipes fit to the wishbones, easy enough transplant to do if you are handy with a welder, or a bit more convoluted it you want to change the complete arms over because you think the original 3 door ones will be worth a million £ in 2 years time
the bolt holes in the chassis were, on the later cars in any case, all the same regardless of it if that a rear arb or not because they are in the box section the beam mount sits in
3dr cossie
21
Nov 20, 2015 05:00 PM
