Fuel pump noise
Old Mar 3, 2014 | 03:15 AM
TheBottleCracker's Avatar
TheBottleCracker
Default Fuel pump noise
Is it normal that my fuel pump whines so loudly? I'm asking because occasionally when I start up the car the engine struggles to start, or it starts but it struggles to get up to 1000 revs. After I bought the car I changed the fuel filter, and I let the fuel drain out from the old filter and it was reeeeeeally dirty. Anyway at the end of the month I'll hopefully get a full check by Oppliger, it's only 20 kms far from my home.
Old Mar 3, 2014 | 06:32 AM
XR2's Avatar
XR2
MFI fuel pumps are a lot louder than standard ones. It's hard to say on a video if it's too loud or not, but it sounds as it should.
Old Mar 3, 2014 | 06:48 AM
mat_rss2's Avatar
mat_rss2
Almost sounds too high pitch as if its low on fuel, do you get any hesitation when boosting?
Old Mar 3, 2014 | 08:52 AM
essexRSTSouthend's Avatar
essexRSTSouthend
Higher pitch or buzz noise indicates wear. Should be a nice low buzz. If it sounds like you low on fuel all time, this also a sign of pump on way out.
Old Mar 3, 2014 | 10:15 AM
jonny s2's Avatar
jonny s2
change the pump
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
kevin36
Sep 8, 2015 12:23 PM
rsturbo27
Sep 5, 2015 05:08 PM
