Bottom end spec for 450-500hp...
Is this bottom end engine spec good enough to reliably run 450-500+hp...
200 block with a standard bore, Cosworth Racing pistons, 7.8:1 comp ratio, 6 studded, WRC headgasket, standard grind crank, big wing sump.
Cheers Paul
Cheers Paul
For the power you want, standard is fine.
Just dont mistake substandard, for standard which is what a lot of people do, there are some positive wrecks of bodged up YB engines out there now.
Mark
I think you can use standard pistons up to 500 - 550, with valve cut outs
The liners could crack at 500 hp,all im saying is there is 600 hp cars out there with standard liners,just making the point that he is well safe around the 500 hp mark..
Mark has picked up on a good point though,why is it on a standard bore?new block or and old bore on a new piston? them questions need to be answered before you throw 500 hp at it?
Ahh ok I see what you mean, it's the bottom end spec on a car I'm tempted to look at that's for sale, but I'm after around the 450-500hp (ballpark) figure, at the moment it's only on greens, a standard head and a t34.
As far as I'm aware it's had a very recent rebuild, I guess the owner built it like that in incase of any further mods/power.
I think it's an old block just fitted with new pistons so am guessing it didn't need over boring and measured up ok....
Cheers Paul
Cheers Paul
Cheers Paul
Cheers Paul
Dont sound right to me mate. The Cosworth Racing pistons would have different tolerances to the standard ones
The only good thing about that is that when using a cosworth race piston its usually a little more skirt clearance needed so if it was a good old block and managed to get honed out to like 4 thou for example that would be about perfect for those pistons..
Before i put 500 hp through it id just have skirt clearance checked..,a bit of a ball ache but no real expense and piece of mind
Cheers Paul
Cheers Paul
Standard bores certainly rings alarm bells on a 20+ year old engine thats already had at least one rebuild.
All depends how anal you want to be,im sure guys that race etc would just chuck a head on it and rag it to see if its good! lol
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
