Cosworth brakes
P8 Managed S1 with ALS
Right chaps I've had both 2wd 4 pots and 4x4 caliper set ups on my own S1 in the past but my mate as bought what were described as 4x4 calipers . Only snag I can find is the bolts that bolt the pad carrier to the hub are too big for the hole in the hub
I've not had this issue before as mine previously just bolted straight on , can anyone suggest why this maybe ? If so am I ok to just drill the holes in the hub out to enable the bolts to fit ?
I would use my own car for reference but I'm on hi specs now so I can't compare
Thanks in advance
Thanks in advance
Aug 14, 2015 07:29 AM
Red_bull
Aug 9, 2015 08:34 AM
