Help with 2.2 tdci knocking from rear
Old Feb 23, 2014 | 06:07 PM
Kairvey Simpson's Avatar
Kairvey Simpson
Default Help with 2.2 tdci knocking from rear
Hello all,
my first post,,,,got a knocking on the rear of my mondeo 55 plate over slight bumpy roads,sounds like a deep knocking noise when suspensions bouncing...could this be drop links?
Also my steering wheel for the first 5-10 minutes of driving sticks in the middle,requires a little force to steer left or right,after 10 mins this disappears but cars still pulling left,tracking been checked and fine.
Cheers in advance
dave
Old Feb 23, 2014 | 06:46 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Ask Dan@fastford He's the resident mondeo guru and has had them all and knows his shit when it comes to them. He'll probably see this anyway as he prowls the internet looking for mondeo owners in trouble to pass on his wealth of experience. He's like superman for mondeo. He can hear the cries of mondeo owners worldwide and reacts as quick as a flash. HE IS MONDEO MAN
Old Feb 23, 2014 | 06:47 PM
Dal_'s Avatar
Dal_
Probably the 4 middle bushes that are knackered.
Labelled 8
Old Feb 23, 2014 | 08:26 PM
Kairvey Simpson
Great thanks mate I'll look him up
Old Feb 23, 2014 | 08:27 PM
Kairvey Simpson
Labelled 8
Cheers mate, do u know if there expensive to buy and fit?
Old Feb 23, 2014 | 09:30 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Rear subframe bushes are very common
Differing views as to whether or not you need the realignment tool after you changed them though
Old Feb 23, 2014 | 10:01 PM
Kairvey Simpson
Cheers dojj. ...I'm hoping they're gonna be covered under my used car warranty I have taken out with warranty wise...got the 5 star cover so hope so lol..gonna book it in next week to have that and the steering wheel sticking looked at, ill let yous know what they find, thanks for the help fellas much appreciated
Old Feb 24, 2014 | 07:07 AM
macrs's Avatar
macrs
As mentioned above, it's probably the rear subframe bushes..
I had exaxtly the same thing on mine! Replaced the drop links first, made no difference..
Then I did the subframe bushes, problem gone.
The ones shown are the powerflex poly-bushes, I used those but they're not cheap!
Hopefully though your warranty will cover you!
Mentioned above are the common bits to go, but get all of the rear bushes checked.
I also had a broken rear spring prior to the subframe bushes going...
I didn't use a realignment tool, just fashioned my own alignment 'pins' for the locations on the subframe.. Seemed to work for me, as 10k miles later on tyre wear is all fine....
Hope this helps mate...
There's some great people on this site that pointed the way for me!!!
Old Feb 24, 2014 | 07:15 AM
dojj's Avatar
dojj
The most common steering issue is a bolt at the end of the steering column that works its way loose
Easy fix with a redesigned replacement boot from Ford
Also, when you replace drop links, the eBay Ł5 versions last about a year, but the fire ones are Ł50 a pop for the fronts and the rears are a right pain if they've rusted into place
Old Feb 24, 2014 | 11:05 AM
Kairvey Simpson
a lot of info there pal.....Thanks very much for ur time n advice, defo sounding like the bushes
Old Feb 24, 2014 | 11:06 AM
Kairvey Simpson
Cheers dojj, not looking forward to finding out what it is but hopefully not too bad lol cheers tho
Old Feb 24, 2014 | 04:33 PM
macrs's Avatar
macrs
No worries mate! Hope you get sorted!
You'll find this a great website for finding help and info.
It's the reason I've become such a car nerd.. ��
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
marky_g
Sep 12, 2015 04:26 PM
cossirob
Sep 3, 2015 09:17 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
