i think my turbo's on its last legs help
pull of the boost hose, the thick one and you will see the compressor wheel,
the shaft in the middle of the compressor wheel should be fairly rigid,
if there is play in it then its caput
should the turbo smoke if it is gone? coz its not smoking the thing is if i take the -31 the chiped ecu and the pace intercooler to tramona garage rich will fitt it and set it up for me but it may be a waste of time if the turbo is stuffed
well the only way to tell if that turbo is kaput (besides turbine impeller blade damage) for now is to take the compressor side of the turbo's air inleft pipe off (right in the middle of the compressor when looking at it from the side) take that off, you will see the compressor impeller blade in there with a bolt down the middle.. grab the top of the bolt and move it sideways, and in and out, and if there is a lot of play (i'd say more than a mm) then yeah that'll be a prob, since the turbo wines roughly 18,000rpms+ and that shaft play will eventually get worse and worse.. later resulting in damaging the compressor housing yielding your turbo pretty much a door stop
if it's whining like a cat i would also check the return oil line back to the oilpan.. sometimes those like to clog and cause your turbo to have oilblow by the centerhousing's seals (either turbine or compressor side seals)
gl to you man
-brad
gl to you man
-brad
JK12
33
Apr 26, 2021 12:09 PM
