Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
ST170 cams into 130bhp 2.0 zetec
Old Feb 12, 2014 | 03:30 PM
mk1 rob's Avatar
mk1 rob
Default ST170 cams into 130bhp 2.0 zetec
Hi All,
Does anybody know if the st170 cams will fit into a blacktop zetec head? As alot of people reckon locking the st170 cam at 110 degrees works well on the original engine I was thinking they would make a really cheap power mod for the standard 2.0. I know the st170 cams have slightly more duration and lift than the normal cams so in theory would work like a fast road set but without the £500 odd price tag as they seem to be around £30 a pair on Ebay. This of course all hinges on whether they will fit. Ive found a picture of the st170 head and can see that the first bearing at the adjustable pulley end is larger than the rest and i'm not sure if they are on the normal 2.0.
Any help and advice greatly appreciated.
Rob
Old Feb 15, 2014 | 04:55 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
Won't fit. Completely different head design and the inlet cam has variable timing with oil galleys in the head
nico12
Dec 31, 2015 04:42 PM
dombanks
Sep 21, 2015 08:38 PM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
